@raphael02 Many thanks for your code. Do you have the same for RF?
On 4/21/2023 at 11:00 PM, raphael02 said:
I added the following "learn" functions myself to the posted hub FQA (LearnIRCode (instead "learn" and GetLearnedIRCode can then be used in the "control" FQA to learn and acquire the code):
function RM4:LearnIRCode(func)
    local payload = makeEmptyTable(16)
    payload[1] = 0x04
    payload[2] = 0x00
    payload[3] = 0x03
    self:sendPacket(
        0x6a,
        payload,
        function(actionResult, errCode, payload)
            func(actionResult, errCode, payload)
function RM4:GetLearnedIRCode(func)
    payload[1] = 0x04
    payload[2] = 0x00
    payload[3] = 0x04
    self:sendPacket(
        0x6a,
        payload,
function QuickApp:LearnIRCode(ipAddress, deviceType)
    local device = nil
    if deviceType and deviceType == 0x51da then
        device = RM4(ipAddress)
        self:debug("RM4")
    else
        device = RM3(ipAddress)
    device:auth(
        function(authResult, errCode, payload)
            --print("AUTH", authResult, errCode, dump(payload))
            if authResult then
                device:LearnIRCode(
--            print("AUTH", authResult, errCode, dump(payload))
            else
                self:error("Can`t auth device " .. ipAddress)
function QuickApp:GetLearnedIRCode(ipAddress, deviceType)
    local device = nil
        self:debug("RM4")
    else
    device:auth(
            if authResult then
                device:GetLearnedIRCode(
             local strOut = ""
             for i, plelement in ipairs(payload) do
             --strOut = strOut .. string.char(plelement)
               -- *** Cut first 6 data elements (prefix 152 0 4 0 0 0 (dec)) form learned code, each valid code starts with 2600 (hex) and edns with 000d05 (hex) ***
               if (> 6) then
                 -- *** Convert returned data from number to ASCII data ***
                 strOut = strOut .. toHex(string.char(plelement))
             print ("Learned code: ", strOut)
            else
The returned code is already hex, so it doesn't has to be base64 decoded and converted to hex before sending.
  • 1 month later...
On 5/9/2023 at 5:50 AM, PallasCat said:
@brv29a you need to downgrade RM 4pro firmware from v62093 to v62092. it worked for me.
How would you access any of those two versions?
I'm stuck on v52079.
  • 3 weeks later...
I upgraded to 62093 via broadlink app on smartphone. then asked support team to send previous version [email protected]
  • 3 months later...
On 19/4/2023 at 7:07, ABDULLAH258 said:
@brv29a Lamentablemente no encontré ninguna solución. Desactivé el antivirus y desactivé el firewall pero no pasó nada.
This is the only solution that can be done, and it did help me to get the IR codes. I did not find any solution to be able to extract the IR codes with the Broadlink Manager application.
Yes I can do it with home assistant in my home or office but this is not capable in client's house so I am still working with linux
  • 5 months later...
Hey @Phenix, is there a current broadlink_hub.fqa working with the RM4 pro?
I tried to follow this video:
I found code on this thread with commands to call the "Broadlink_hub (v7).fqa" and use its learn function, but apperantly the "Broadlink_hub (v7).fqa" does not provide this function?
I have seen @mrmoon having the same issues, but i checked the ID i am using and i set it to the Hub. Is it necesarry to set the device hex code for RM4 Pro to 0x5212? But even with this adjustment, i have the problem of not having a learn function. Another person here added custom learn functions, but they seem to only work with the RM4, as he asks for the specific hexcode of the RM4.
Any help would be great!
  • 1 month later...
Hi - I’ve not looked at this for a while as I migrated to HA. Let me get my head around it again and I will come back to you
function QuickApp:learnRM4()
    self:debug("button1 turned on")
    self:updateProperty("value", true)
fibaro.call(219, "learn", "192.168.1.94", 0x51da) -- Only for RM4
  • 3 months later...
I lost my YouTube channel, but created a new one with the same tutorials uploaded - ContineoHomes if you are looking for the how to videos on this topic
let me know if you need any help?
  • 3 months later...
 The 62092 version:url:
and here i change one code with version 62093:
Edited by lux
for discover button error ! here i change one code with version 62093:an error appears: "Error: discovery msg - incorrect size"
files > manager:
Edited by lux
