jgarbayo 0
I´m replacin old X10 dimmers, all Dimers are connected to more than one momentary switch. The current wiring takes a single wire from the momentary switch to the dimmer. This wire closes the line (L) circuit. In order not to have to add one more wire to all of the installation, i tried to connect the cable that comes from the momentary switch directly to the S1 and everything works. The connection scheme is attached.
As you can see it does not correspond to any of the options in the manual, before buying the rest of the Dimmer 2 modules, I would like you to confirm that this type of connection does not generate any problems.
