/monthly_2020_05/image.png.a16cba642eb6dca1e2a4f84f99d758c2.png" />
so,. now you can trigger event if nobody at home.
V2
    type = "custom-event",
    property = "unifi_presence",
    operator = "==",
    isTrigger = true
print(json.encode(sourceTrigger))
print(fibaro.getValue(1842"userDescription"))
V3
username / password
V4
V5 - improvements
Edited by 10der
almost, getting after each init 401 (probably set Cookie)
/monthly_2020_05/image.png.c8c4475e663b2e2a1cbd42e4a3e7b5cc.png" />
but it works second later
On HC2 i was using modified solution from Lazar, measured Signal strenght and availibility of smart watch, iPhone and Laptop (to reduce/avoid issues with empty battery on one device = Alarm set and siren activated just after i moved a bit in my bed …)
    @tinman strange.
    1st call should be 401
    than login OK
    and silence.
    Guest Freddan67
    Seems to work fine but how can I do if I want to run a scene if person 1 comes home and person 2 is gone ?. (I'm still pretty new at LUA so I ask to learn)
    @Freddan67 fixed
    [19.05.2020] [10:01:11] [DEBUG] [SCENE30]: {"Oleg":{"state":true,"oldState":false}}
    DECLARATIONS (Conditions/Triggers)
        operator = "==",
        isTrigger = true
    ACTIONS
    QA updated.
    Guest Freddan67
    25 minutes ago, 10der said:
    @Freddan67 fixed
        operator = "==",
        isTrigger = true
    ACTIONS
    QA updated.
    Thanks. I'll try when I get home if I understand :)
    /monthly_2020_05/image.png.0004fc0484eaea2690abb88f5226c7fd.png" />
    Guest Freddan67
    12 minutes ago, 10der said:
    Thanks @10der. I want to start sonos in the kitchen when I come home and my wife is not home so now it will be fun to try to get it together.
    V5. some improvements
    • 2 months later...
    I got the same issue, keeps saying Login OK and Wrong status in the debug screen. Restarted the Unifi Controller and Homecenter 3, but doesn't help.
    @chiel-s just a moment
    this work propepry. idk
    Thanks for the quick reply. Unfortunately the same problem with this version.
    btw 401 always will be here... when token is expire or missing.
    OK - said what token now OK and all went OK
    Edited by 10der
    • 8 months later...
    At variables, What is the "site" ?
    How I can setup the variable to suit my home environment?
    I am the beginner. Please teach me.
    Edited by Jaejin Lee
    /monthly_2021_04/image.png.7dfaca39abe45dabcc40716d62243299.png" />
    20 minutes ago, hater said:
    Thank you so much.
    Have a nice weekend!
    • 2 months later...
    Is there a way to make this work with a UDMP?
    Or maybe another method?
    • 3 weeks later...
    is this working with the udmp ? becus  i cant get it to work ?
    • 3 weeks later...
    Hi guys.
    Can anyone help?
    I have added the quick app in and now keep getting the following: -
    Can anyone help out?
    [20.08.2021] [17:53:00] [DEBUG] [QUICKAPP150]: loginUnifi() succeed
    [20.08.2021] [17:53:10] [TRACE] [QUICKAPP150]: checkMacUnifi() succeed
    [20.08.2021] [17:53:10] [ERROR] [QUICKAPP150]: QuickApp crashed
    [20.08.2021] [17:53:10] [ERROR] [QUICKAPP150]: /usr/share/lua/5.3/json/decode/util.lua:35: unexpected character @ character: 2 1:2 [<] line:
