Sounds like a special character in username or password the code doesn’t handle well?
Thanks for the speedy reply.
I did indeed have an ! in my password. I now just have upper and lower case litters and still getting the same error.
Any ideas?
[20.08.2021] [18:22:00] [DEBUG] [QUICKAPP150]: loginUnifi() succeed
[20.08.2021] [18:22:10] [TRACE] [QUICKAPP150]: checkMacUnifi() succeed
[20.08.2021] [18:22:10] [ERROR] [QUICKAPP150]: QuickApp crashed
[20.08.2021] [18:22:10] [ERROR] [QUICKAPP150]: /usr/share/lua/5.3/json/decode/util.lua:35: unexpected character @ character: 2 1:2 [<] line:
[20.08.2021] [18:23:00] [WARNING] [QUICKAPP150]: Variable away delay not found
[20.08.2021] [18:23:00] [DEBUG] [QUICKAPP150]: onInit(): away delay equals frequency
[20.08.2021] [18:23:00] [TRACE] [QUICKAPP150]: setPresenceStatus() called: Unknown
Also, this is the controller url that I'm using: - https://10.10.1.230/network/site/default/dashboard/
you have an udm?
if so, there is a change that qa does not communicate with unifi os
Sorry, I should have said, I have a Unifi Cloud Key Gen 2 Pro.
yes, that is running unifi os, cloud key gen1 runs other software
    I am also. It works for me
    Aha, i did not know, the plugin i use for unifi, you have to choose wich cloudkey you are using. so i assumed that they comminucatie different
    Where did you get that view from. I have not seen that before.
    @akatar I have a udmp network overhere, could you share what you have there ?
    I am using homeseer 4, this is the unifi plugin for that, you see every unifi device you have
    Edited by akatar
    Ok thanks :)
    Another extra piece of extra software, to achieve what i want with the HC3 :P
    I will end up with a shitload of extra hardware running stuff that the HC3 cant.
    Just now, ppeterr said:
    Ok thanks :)
    I only use hc3 for zwave, all the other stuff i use homseer for
    To be honest, zwave is the only thing that works great on hc3
    Ahh wel, i'm pretty fresh. But still happy with it all. It all looks very stable, for what i am doing with the HC3.
    My problem is that i always want more, beyond the capabilities of the hardware. And well...thats pretty fast
    for the HC3. Anyway Homeseer aint that expensive, might be worth to look into it one day.
    I bought homseer 2 secondhand, and upgraded to hs3 to hs4 every update was 60 euro's orso
    Just browse to the plugins for hs4
    funny thing....
    for most zwave controllers is a plugin for homeseer, vera, smarthingshub, hubitat etc but not for fibaro homecenter, i guess nobody wants that :)
    Well there might be a solution for the udmp+rpi+(influx maybe)
    One of the things i actually use and afaik not possible with fibaro is sending chat messages with telegram to homeseer.
    It sent me updates (the ones i want) and i can sent a message if i want the system to do something when i am around or not
    Thing is, that one of the main purposes of the hc3 in my opinion, is to combine all that have around the house and
    use that from one platform. Or at least, that was my plan. I think that's not gonna work out like that.  The last few months
    i've been adding more hubs/rpi's/sensors etc then the last 5 years :)
    I like it a lot till now how everything works. But its getting more complex with every idea to work out.
    Maybe it's fair to say, that sometimes the limitation is my knowledge. But well....i'm willing to learn.
    I wonder, what kind of things you want to do, by sending a msg through telegram?
    Getting really off-topic with all of this :)
    Anyway Upoller is a script that indexes all functions from a udm/p usg etc. And puts that in influxdb.
    it seems it got a API. So maybe...just maybe i can work out how to fetch the info about who is connected to the network.
    @ppeterr I do not use the apps that belongs to the system, i don't want to scroll to stuff
    If i want to (example) turn on my poolpump for an extra round, i just sent an app: poolpump on
    If there is someone that want to enter my home and have a key but don't have the alarmcode, this happens i simply sent an app: alarm off
    The mesages i get for example
    we got mail (real mail)
    there is someone at the door
    etc
    and true story
    i have pirs around my house to turn on the ouside light, but they only work to 2 oclock in the morning, once every couple of weeks i go to a couple of friends to drink.
    When i come back it's after 2 oclock and i sent an app to turn on the lights then, to drunk to do it any other way
