rmont 0
I am trying to connect the smart implant to an alarm with 12v outputs to signal "alarm armed" and "alarm active" (i.e. breach identified).
I connected the SI using the inputs as analog. I can see the correct voltage on the analog inputs (i.e. +12v = armed / 0v = unarmed).
But I can't make the smart implant to generate events (i.e. open/closed/switched) when the voltage changes. I can only poll the voltage periodically to check if it has changed.
I have already fiddled wit parameters 63 (input threshold) and 64 (periodical report) with no success.
What is the right way to generate events when the voltage changes from 0 to 12v?
Roberto
