SmartHomeEddy 1,008
This QuickApp reads the PM2.5, PM10, Temperature, Humidity and Airpressure values directly from a sensor somewhere in this world
That sensor doesn't have to be your own sensor, any sensor can be used, just find one in your neighborhood
For locating the sensor(ID's) in your neighborhood see:
Select two (!) SensorID's, one for PM2.5 and PM10 values and one for Temperature, Humidity and Airpressure values
The PM2.5, PM10, Temperature, Humidity, Absolute Humidity and Airpressure readings are stored in the value of six (child) devices, so you can read the value from your own scenes
This QuickApp will send notifications when PM2.5 or PM10 readings reach a breakpoint (if userID ~= 0)
Absolute humidity is the measure of water vapor (moisture) in the air, regardless of temperature. It is expressed as grams of moisture per cubic meter of air (g/m3)
See also
See also for CVS files:
See also
API documentation:
QuickApp variables (mandatory, they will be automatically added with the default values):
Version 1.0 (7th February 2021)
Version 0.4 (19th August 2020]
Version 0.3 (15th June 2020)
Version 0.1 (13th June 2020)
Suggestions are welcome. If someone feels the need to improve the QuickApp, you are very welcome.
Download the QuickApp here (download the file and un-zip):
or Fibaro Marketplace:
How to install:
Edited by SmartHomeEddy12 answers to this question
