I am having some trouble with 2 HCL that have static IP and are controlled by the master HC2, but I have seen that they change back to another IP, and don´t know why
Any suggestions?
How have you set the static IPs?  This thread has some clues for you:
My suggestion is to always configure network static addresses in the router, using DHCP address reservation.  That way you have a single source of truth and control over IP addressing - no more IP clashes.  Each of your devices can then simply use DHCP, and if they have a reserved address in the router then they are served up the same address every time.
I allocate say 192.168.1.1 to 192.168.1.200 for dynamic IP address allocation, and I use 192.168.1.201 to 192.168.1.250 for static allocations based on MAC address.
