10der@,  chiel-s @
6 hours ago, chiel-s said:
@10der, is it possible to configure settings for hue lights? Such as:
Would be great. The last piece to finalize my light automation :-) I have tried 'level' but that seems not be working for Hue lights.
Hmmm... why it’s not single command... but ok will do
ahh no!
it doesn't work. sorry. My script always want to know the current status of lighting (switch / dimmer / etc).
so, please put your HUE to QA  as switch or dimmer. update value according to the current state of your HUE
and provide this QA id for my script.
    3 hours ago, 10der said:
    ahh no!
    Hmm ok. And if you only add the Brightness? Because that's the equivalent of the dim level. Woud that be possible?
    @chiel-s I thonk you not clear understand me....
    yes, I can turn on anything... but you back to me in 5 min and asking me wht script trying turn on lights every 5 sec.
    so yes i can changeBrightness to 255 but how script check what Brightness is 255.
    so, please attach me response
    http://192.168.1.36/api/devices/29
    where 192.168.1.36 ip address of your HC3
    also level can be as DImmer 0..99 or for color 0..255
    Edited by 10der
    @10der, thanks for your quick reply and thank you for adding this to your script. I really appreciate that and I think a lot of other people on this forum as well! When hue is going to be supported I think this is a must-have-script for everyone owning a fibaro home center ;-) It's so flexible ;-)
    I added the QA but the lights are not turned on. After commenting the --jT = json.decode((fibaro.getGlobalVariable("HomeTable"))) line the script (I am not using a hometable), the QA starts succesfully but the lights are not reacting. When I enable the debug mode I get the following message:
    Edited by chiel-s
    Ok. Can we close this Qa and just simple create a new scene
    empty LUA scene
    ok? Ready?
    yeah
    just in blank right panel
    fibaro.call(29, “setColor”, 0,255,0,0)
    run
    your HUE should start green color
    if not - strange
    Btw
    can you try
    level = 255
    actions": { "setColor": 1, "setValue": 1,
    According you device it should support this commands
    empty LUA scene
    ok? Ready?
    yeah
    run
    if not - strange
    Btw
    can you try
    level = 255
    @10der,
    returns in:
    I don't think that it supported? I know that the following is working:
    Also good to know that Philips Hue always needs the fibaro.call(29, "turnOn") line to turn it on. When calling changeHue or changeBrightness won't turn the light on. At this moment none of my Hue lights react, also the rooms without any level settings defined. Level 255 is also not working.
    Edited by chiel-s
    please check:
    should be
    You are using bad char
    17 minutes ago, petrkl12 said:
    please check:
    should be
    Could be, but I also cound't turn them on via the user interface. Rebooted homecenter.
    When I run:
    The light goes on and turns green. So you were right, that is working. Debug mode returns (my timeout = 5 now):
    When I trigger the motion sensor the light doesn't turn on. Debug returns:
    Edited by chiel-s
    ok, I do not know about turnOn is mandatory for HUE.
    will fix
    @chiel-s
    1 hour ago, 10der said:
    Thanks @10der!! It is working! :-) Great! The hue lights react now and I can set the colour. Is it also possible to set the brightness of the hue light? I thought I could use the 4th value? Where '99' and '10' are the brightness. But that is not working.  In example:
    just assign level as integer
    level = 255
    @chiel-s OMG. I forgot what HUE has bug and I should add
    fibaro.call(id, "turnOn")
    @chiel-s can you change body of QA.
    I am busy with the current work now. sorry, can`t re-publish QA in the topic.
    thnak you!
    Edited by 10der
    PS: according to Fibaro docs
    "0,255,0,0"
    r,g,b,w
    brightness - my guess independent
    @10der another fix
    v1.2.090920.3
    so, now you can use (or not use) 5 params in color.
    r, g, b, w
    or
    r, g, b, w, brightness
    level = "0,255,0,0,10",
    @chiel-s
    Edited by 10der
