Automatic Lightning System for HC3 (Motion/Average Lux)
chiel-s
  • 22 hours ago, 10der said:
    @10der another fix
    v1.2.090920.3
    so, now you can use (or not use) 5 params in color.
    r, g, b, w
    or
    r, g, b, w, brightness
    level = "0,255,0,0,10",
    @chiel-s
    Unfortunately not working. When i set the brightness of a hue light to 10% in the user interface of Homecenter and after that run your script, it resets back to 99% brigthness. Using the following code:
    Also good to know: the order of actions can have impact. Normally I turn the Hue light on and then set the brightness and colour. The other way around can be buggy. But colour seems to be working stable now in your script.
    @10der,
    When i remove the level settings, the lights do not react. When i set level = 20 (integer), lights do not react.
    They only react when I set for i.e. level = "250,202,8,0,150", but the brightness is always 99% for all hue lights in the room.
    Hope this helps.
    Cheers,
    Chiel
    Edited by chiel-s
    @chiel-s ask autgor of HUE to fix own QA.
    I do not want dancing around ugly QA.
    with my REAL color conroller (Fibaro LEd strip) works like a charm
    with my QA with type "color conroller" work like a charm.
    idk what happened with HUE QA
    sorry
  • 6 hours ago, petrkl12 said:
    I think he is using standard fibaro plugin for hue lights...
    Ehm yes. Is it working in combination with your QA @petrkl12? (
    In that case I will give it a try ;-)
    • 4 weeks later...
    Really nice QA.. Is it possible to use Profile and GlobalVariable as part of the dependencies also?
    Yes you can
    just provide global name instead of I’d
    3 minutes ago, 10der said:
    Yes you can
    Arh, this is perfect.. like
    sensors = {194199, SleepState=Awake, Profile=1 }..
    I have an outside light which has no Sensor or anything.. How do I get this to only turn on and off at specific times (sunset..23:55) and (04:30..Sunrise)?
    I have tried not entering sensors, but the scene the only turns the light off..
    @Ace02 ahh stop! i am wrong!
    you are asking about profile.
    no.
    this feature now in development
    /monthly_2020_10/image.png.cebc8fd12db77f48d21f9dbb9f05e228.png" />
    Okay, no profile yet.. :-) But I can use the GlobalVariable?
    i tried this for my outside light, but does not seem to work:
    Udelys = {
           name = "Udelys",
            sensors = {},
            luxs = {},
            minLux = 99999,
            powers = {175},
            level = 25,
            times = {
            ["$Sunset..23:55"] = { level=25 },
            ["04:30..$Sunrise"] = { level=25 }
    What am i doing wrong with this one.. It only turns my light of.
    I don't know why my post looks like this.. ?
    I'm trying to accomplice two things.
    1. to use globalvariable and profile in your QA - Profile not possible at the moment OK.. Is the globalvariable put in like this: Sensor=( 192, globalvarible=value )??
    2. I want my outside light to only react on time.. I have tried removing all sensors from the scene like in above post, leaving only Powers and Time variables.. But it does not seem to work that way.. How can i do this in order for it to work?
    well.
    here is source with profile.
    you can use profile in times
    how to set profile?
    it's not teh same profile what fibaro use
    just call
    fibaro.call(QAid, "setProfile", "MyTestProfile")
    from scene for example
    or clear
    fibaro.call(QAid, "setProfile", "")
    about using global var for turing on of
    lighting = {
         Test = {
             name = "Test",
             debugMode = true,
             sensors = {'Test'},
             luxs = {},
             powers = {989},
             timeout = 60 * 1
    21:32 | October 06, 2020 loaded 1 lighting rules
    21:32 | October 06, 2020 started...
    21:33 | October 06, 2020 Test Sensor breached
    21:33 | October 06, 2020 Test [on : 99]
    QA
    Udelys = {
           name = "Udelys",
            sensors = {},
            luxs = {},
            minLux = 99999,
            powers = {175},
            level = 25,
            times = {
    See example below. I use global variable for my TV and my Sonos in the kitchen. Make sure to use 0 (off) and 1 (on) as value for the gobal variables.
    • Thanks 2
    • 4 weeks later...
  • Hi @10der,
    I am replacing my hue lights with Fibaro Dimmer 2 modules.
    Setting level is not working in the latest version you shared in this thread.
    Is it supported in this version? Level = 100 is not working for instance.
    Thanks!
    • 1 month later...
    I'll use this great script and it works perfectly.
    Try profiles now, but somehow that doesn't work.
    Setting the Profile goes well through a scene.
    Debug log -- > [14.12.2020] [18:06:38] [DEBUG] [QA_MOTION_LIGHTS_102]: onAction: {"args":["MyProfile"],"actionName":"setProfile,"deviceId":102}
    the definition I use is:
     test = {
            name = "Testing",
            sensors = {108},
            luxs = {110},
            powers = {243},
            timeout = 5,
            times = {
                ["06:00..22:00"] = {
                profiles = {
                    ["MyProfile"] = {
                          timeout = 60
    Can anyone see what I'm doing wrong
    juts a moment
    thank you for your quick response and the bug fix. It now works perfectly. I am very happy with the result
