HC3 with LG SmartThinq ?
Hello.
Does anybody have plan integrating LG SmartThinq to HC3?
There's a code.. at   "
I can't convert that code(core.py) to lua...   (e.g.  create session, Get the base64-encoded SHA-1 HMAC digest of a string .. etc)
Somebody help me~ :)
On 4/26/2021 at 2:11 PM, rangee said:
As it is not stable, I can not share it.
I use dryer, washer, dehumidifier.
Get status of devices works but sometimes got error.
Control of devices same.
Did you get it to work ?
Any update on this topic?
You can add a QuickApp for LG ThinQ in two ways:
  1. Using a lightweight plugin running in a container on Synology.
    It receives information from LG via an API key, generates an API page, and from there you can pull the values and build your own QuickApp. (This is the method I’m using now.) Was developed by my colleague Vlad and we polish the QA to work correctly. Now you can use all values as globals and make your own scenes.
    We use in combination whit our Victron Energy plugin and when production is over 3000W, LG start and set target value to 25ºC (is just an example) Bellow screen from FastAPi on Synology and LG QA fully functional.
  1. Using ioBroker in a container on Synology/Linux/etc.
    ioBroker connects to LG using your account and password, then broadcasts all the device information and values over TCP. You can then capture those values directly in your QuickApp.
