SmartHomeEddy 1,006
This QuickApp can be used as your Fibaro Homecenter 3 Weather Provider (Settings - 6. General - Main - Main Devices - Weather Provider)
The Buienradar Weather QuickApp contains the current Dutch weather measurements, the weather forecast and the 5-day forecast
The 5-days forecast is shown in the labels and the tomorrow forecast is shown in the child devices
The current observations are measured by KNMI weather stations spread across The Netherlands and are updated every 10 minutes
The weather report is updated several times a day by the Buienradar meteorologists
The QuickApp has child devices for:
This QuickApp is plug-and-play. The only thing you can do, is change the Station ID to a weather-station nearby from the list or add some nice icons to the devices.
Changes version 4.0 (15th June 2026)
Changes version 3.0 (23rd March 2022)
Changes version 2.1 (15th January 2021)
Changes version 2.0 (3rd January 2021)
Changes version 1.0 (25th October 2020)
Changes version 0.6 (9th September 2020)
Changes version 0.5 (4th September 2020)
Changes version 0.4 (22nd August 2020)
Changes version 0.3 (11th August 2020)
Weather conditions:
The Buienradar weather description is converted to the right Fibaro condition codes, with the icons:
/monthly_2020_09/0F1673AC-6806-4F30-B7DA-26BCD55F5063.jpeg.029fe086520bc114b2008f60d968c359.jpeg" />Fibaro Dashboard:
The Fibaro properties Temperature, Humidity and Wind values are updated to show in your dashboard:
Mobile App:
For the Mobile app these values are available:
For the most accurate measurements you can select a Station in your neighborhood:
6391 Meetstation Arcen / 6275 Meetstation Arnhem / 6249 Meetstation Berkhout / 6308 Meetstation Cadzand / 6260 Meetstation De Bilt / 6235 Meetstation Den Helder / 6370 Meetstation Eindhoven / 6377 Meetstation Ell / 6321 Meetstation Euro platform / 6350 Meetstation Gilze Rijen / 6323 Meetstation Goes / 6283 Meetstation Groenlo-Hupsel / 6280 Meetstation Groningen / 6315 Meetstation Hansweert / 6278 Meetstation Heino / 6356 Meetstation Herwijnen / 6330 Meetstation Hoek van Holland / 6279 Meetstation Hoogeveen / 6251 Meetstation Hoorn Terschelling / 6258 Meetstation Houtribdijk / 6285 Meetstation Huibertgat / 6209 Meetstation IJmond / 6225 Meetstation IJmuiden / 6277 Meetstation Lauwersoog / 6320 Meetstation LE Goeree / 6270 Meetstation Leeuwarden / 6269 Meetstation Lelystad / 6348 Meetstation Lopik-Cabauw / 6380 Meetstation Maastricht / 6273 Meetstation Marknesse / 6286 Meetstation Nieuw Beerta / 6312 Meetstation Oosterschelde / 6344 Meetstation Rotterdam / 6343 Meetstation Rotterdam Geulhaven / 6316 Meetstation Schaar / 6240 Meetstation Schiphol / 6324 Meetstation Stavenisse / 6267 Meetstation Stavoren / 6229 Meetstation Texelhors / 6331 Meetstation Tholen / 6290 Meetstation Twente / 6313 Meetstation Vlakte aan de Raan / 6242 Meetstation Vlieland / 6310 Meetstation Vlissingen / 6375 Meetstation Volkel / 6215 Meetstation Voorschoten / 6319 Meetstation Westdorpe / 6248 Meetstation Wijdenes / 6257 Meetstation Wijk aan Zee / 6340 Meetstation Woensdrecht / 6239 Meetstation Zeeplatform F-3 / 6252 Meetstation Zeeplatform K13
QuickApp variables (mandatory, they will be automatically added with the default values):
or Fibaro Marketplace:
How to install:
JSON data copyright: (C)opyright Buienradar / RTL. All rights reserved JSON data terms: This feed may be used freely under condition of source reference buienradar.nl including a hyperlink to https://www.buienradar.nl. The feed cannot be derived from users or other persons.
Edited by SmartHomeEddyTop Posters For This Question
39
9
4
3
Feb 18
7
Sep 9
6
Apr 24
5
Oct 6
5
SmartHomeEddy 39 posts
ppeterr 9 posts
Hearts 4 posts
_Wilco_ 3 posts
Feb 18 2022
Sep 9 2020
Apr 24 2022
Oct 6 2021
SmartHomeEddy
Sneak Preview of the next version 2.0 Please login or register to see this attachment. Please login or register to see this attachment.
SmartHomeEddy
This QuickApp can be used as your Fibaro Homecenter 3 Weather Provider (Settings - 6. General - Main - Main Devices - Weather Provider) The Buienradar Weather QuickApp contains the current Dutch wea
SmartHomeEddy
A completely new QuickApp Buienradar Weather is available. With the spring coming you might need a weather forecast for your sprinklers or lawn mower. Several child devices are added to give you that
68 answers to this question
