Guest muhmuh
im looking for a HC3 Script which switch a Bathroom Fan on/off with dependency relative humindity.
I found a HC2 Script from kapitano1 (https://forum.siio.de/t/lua-taupunktlueftung-im-keller/5206)
My Lua skill is very low, so i tried to change the code to hc3 and add my ids.
The script will run correctly when humidInAbs - humidOutAbs > 1 but the switch off fan code is not correct.
And sorry for my english, but it is not my native language; i tried my best.
Can anyone correct it please?
Debug:
28.08.2020] [12:44:00] [DEBUG] [SCENE218]: - 28.08.2020 12:44:00 AußenTemp 21.59°C rel. Feuchtigkeit 57.0%
[28.08.2020] [12:44:00] [DEBUG] [SCENE218]: - 28.08.2020 12:44:00 absolute Luftfeuchtigkeit Außen 10.969697021231g/m³
[28.08.2020] [12:44:00] [DEBUG] [SCENE218]: - 28.08.2020 12:44:00 InnenTemp 25.4°C rel. Feuchtigkeit 51.0%
[28.08.2020] [12:44:00] [DEBUG] [SCENE218]: - 28.08.2020 12:44:00 absolute Luftfeuchtigkeit Innen 12.211619119493g/m³
[28.08.2020] [12:49:00] [ERROR] [SCENE218]:
11
9
6
Nov 12
15
Nov 11
13
Aug 29
6
Sep 5
5
SmartHomeEddy 20 posts
10der 11 posts
ErikP 9 posts
ppeterr 6 posts
Nov 12 2022
Nov 11 2022
Aug 29 2020
Sep 5 2020
SmartHomeEddy
With the help of InfluxDB and Grafana I got a great insight of a comparison of the humidity. Because I now can compare Absolute Humidity, it is more easy to get a better setpoints for my Fan
10der
@muhmuh do not forget setup Id's via variables pressure device - optional. default is Standard sea level pressure is 1013 hPa switch - also optional.. default only
SmartHomeEddy
Is the absolute humidity “kg/m3” or “g/m3” instead of “%” ?
62 answers to this question
