Guest muhmuh
im looking for a HC3 Script which switch a Bathroom Fan on/off with dependency relative humindity.
I found a HC2 Script from kapitano1 (https://forum.siio.de/t/lua-taupunktlueftung-im-keller/5206)
My Lua skill is very low, so i tried to change the code to hc3 and add my ids.
The script will run correctly when humidInAbs - humidOutAbs > 1 but the switch off fan code is not correct.
And sorry for my english, but it is not my native language; i tried my best.
Can anyone correct it please?
Debug:
28.08.2020] [12:44:00] [DEBUG] [SCENE218]: - 28.08.2020 12:44:00 AußenTemp 21.59°C rel. Feuchtigkeit 57.0%
[28.08.2020] [12:44:00] [DEBUG] [SCENE218]: - 28.08.2020 12:44:00 absolute Luftfeuchtigkeit Außen 10.969697021231g/m³
[28.08.2020] [12:44:00] [DEBUG] [SCENE218]: - 28.08.2020 12:44:00 InnenTemp 25.4°C rel. Feuchtigkeit 51.0%
[28.08.2020] [12:44:00] [DEBUG] [SCENE218]: - 28.08.2020 12:44:00 absolute Luftfeuchtigkeit Innen 12.211619119493g/m³
[28.08.2020] [12:49:00] [ERROR] [SCENE218]:
On 11/12/2022 at 4:19 PM, ErikP said:
Indeed so version 6 or 7 you should use in usb mode. When on battery and with aerq you have only battery mode. To conserve battery reports to console are not realtime. So in this use case not ideal because I guess you want the fan to kick in directly when needed....
Thanks Sjakie for pointing out the difference
After some research and a lot of settings tweaking i foud out that parameter 48 is important to set.
This enable's the treshold to function above the 60% humidity level. So, setting the treshold at 2 or 3%,
and sensor limit control on option 2. Makes it almost real time when using it with a battery.
These parameters are set by default if you use usb-mode.
i recommend the new Zooz sensor for inside or outside temp and humidity:
The link says 700 series, but it is already the 800 series based one, with nice mounting bracket
