HC3 Scene (light) Devices (more than one) trigger
NLWaard
Is it possible to write a (one) trigger for the HC3 scene that responds to all devices, whose interfaces are light.
I don't want to write for every light device a trigger..
What I've tried, and it doesn't work is:
OR id=
OR id= fibaro.getDevicesID
And changing 'device' to 'interfaces' or 'interFaces' doesn't work either.
The only code that's working is:
But, this trigger is only for 2 devices, and I have a lot more....
And I don't like it because it's hard to maintain..
Can someone help me with this? please!
Edited by NLWaard
At JCab's indication, I changed 'all' to 'any
OR id=
and it should be "any", not "all".
...and no, I don't know of any other way to do it.
condition section like a HC2 header triggering can trigger only on "specific value" - device id for example and does not mean "like" values or "calculated" values.
alas. and it's pain
Edited by 10der
Is it ok to do this?
Edited by Arnes
posted before i was finish
@Arnes Hey, Cap!! we are stil talking about condition window?
/monthly_2020_09/image.png.8dc1b1a29d034ab0459fffdcb4f90271.png" />
Edited by 10der
4 minutes ago, 10der said:
Quote
But is this a OK solution to do this as an action? Since it is not possible to do in condition.
    Okay, I think...
    But what do you think, should be the trigger to perform this action?
    and, is a QA not better then (because of the loop)?
    thanks to you both!
    ? What you say makes sense .. (but the strange thing is, both codes work ?..)
    changed it to 'any', Thanks..
    1 hour ago, NLWaard said:
    Okay, I think...
    thanks to you both!
    Yes you might have right. Have the same problem as you, and just started to learn . I have to look at QA.
    Anyone have some idea how to do this with QA?
    Yes, you can do this.
    I would recommend
    instead of sleep.
    If you move to a QA you could try
    that is created for just this kind of stuff.
    It does look at all triggers generated by the HC3 but tries to be a bit smart and only invoke rules when they can be triggered.
    It's also easy to add recurring or daily schedulers.
    I would recommend
    instead of sleep.
    I tried this in my 0,15%,50%,99% light bulb, as you indicated,
    but with this it looks that you create a new class and can't refer to the main class where you are working in.
    In other words, you can't use self:.... I even had to change self:debug() to print(). ???
    Besides that, it looks odd to me, like you are building a stack,
    before the fuction is finished you call it again.
    Or am I wrong...
    You are the expert ;)
    Or am I wrong...
    You need to be in a scope where you have access to 'self'
    Ex.
    setTimeout returns immediately without calling the function,  and after x ms the system will call the function for you in a new "thread". No stack is built-up.
    See explanation here
    sounds like music to my ears.
    Is it easy to understand?
    I already wanted to build something like that.
    A QA that checks light intensity and then sets variables that in turn switch devices...
    and more One big main loop for all (or any).
    to keep the HC speedy..
    thanks for sharing, I will dive into it.
    Ex.
    Ahum ??. thead's...
    I like thread's, harder to understand, but much better performance...
    I have changed 'sleep' into 'setInterval' as you indicated earlier.
    (I don't know. i think i'ts me. but that 'timeout' in the loop itself...).
    and guess what...  now it works, as it should.
    Thanks again, and like I said, you'r the expert..
  • By fine-tuning the code, I changed the following code by an anonymous function (Lambda expression)
    Sorry moved to the parent child question.
    Edited by NLWaard
    moved to correct location, and change Lambda to anonymous function
    Lambda expression,
    LUA?! Lambda expression??!
    OMG! :)
    OMG! :)
    Haskell programmer?
    Jan!!!!
    it hit me.
    what LUA lambda function is :)
    18 minutes ago, 10der said:
    Jan!!!!
    it hit me.
    You have seen the light - welcome to a more functional world ?
