odelrio 0
Hello:
I think that my scenario is very common, but I can't find or can't understand how to wire it. In the junction box where I'm installing the Dimmer 2 (FGD-212) I have Live, Neutral and the end of a 4-way switches circuit that works with Live. My switches are toggles, not potentiometers (wheels). I want to dim the light only remotely and to use the physical switches to turn the light on and off. I see no reason to power my switches from Sx.
I can't understand the 2-wire or 3-wire schemas in the manual. Why is Neutral connected to Sx sometimes? Isn't Sx the Live output for the switches?
Can I power the switches directly from Live and then feed S1 with it? See the attached schema.
Thank you!
5 answers to this question
