konundrum 0
Newbie here.
I have a sliding gate that I have added control using a Fibaro switch so I can open and close the gate using Fibaro HC3. (working fine)
I have added a Reed sensor using a Fibaro Smart Implant input so I can see if the gate is closed. (working fine)
I have set up a scene that I will want to be able to run manually to open the gate, but only if the gate is closed. Is there a way to set this up?
When manually running the scene it appears to ignore any of the conditions and just runs the scene.
Have tried searching but only things i can find are in HC2 and HC3 seems to be setup differently and I can't translate the instructions.
22 answers to this question
