Manual Scene to Open Gate IF gate closed
Newbie here.
I have a sliding gate that I have added control using a Fibaro switch so I can open and close the gate using Fibaro HC3. (working fine)
I have added a Reed sensor using a Fibaro Smart Implant input so I can see if the gate is closed. (working fine)
I have set up a scene that I will want to be able to run manually to open the gate, but only if the gate is closed. Is there a way to set this up?
When manually running the scene it appears to ignore any of the conditions and just runs the scene.
Have tried searching but only things i can find are in HC2 and HC3 seems to be setup differently and I can't translate the instructions.
6 hours ago, konundrum said:
Parece estar configurado corretamente. Portanto, quando o plugue da parede for ligado, se o sensor estiver fechado, o portão será aberto.
MAS
você precisa configurar outra cena, bastando ligar o plugue da parede. Então essa é a cena que você ativa. Em seguida, irá disparar esta cena acima automaticamente.
Acho que, como outros disseram, se você acionar manualmente uma cena, as condições são ignoradas, mas se for acionado automaticamente, não ignora as condições
Thanks I already got it :)  :) @SmartHomeEddy gave a help
Small typo in Fibaro script ?
