Hi dear,
I have the HCL and I should like to know to get the weather yesterday, it's possible?
If is possible how to configuration in HCL?
33 minutes ago, SmartHomeEddy said:
Yesterday ?
no, cuz HCL do not support raw http requests
    Yes, yesterday.
    I validate if rained yesterday to doesn't turn on irrigation in today.
    Would this validation be in LUA?
    • 1 month later...
    I can think of solutions. Maybe someone will fix me because I don't know all the limitations of HCL. Since it doesn't have LUA, I assume you can work with scenes.
    Periodically load the condition, if the breasts, add to the global variable type PSI = cumulative collision every hour. Every midnight this would be overwritten in the Variable variable, or set PASS = True and the PRSI variable will be reset.
    I say, I have no idea if it will be possible with the help of block scenes.
    eM.
