HC3 - Sonoff Tasmota temperature sensor via MQTT
I have Sonoff temperature/humidity sensor flashed with Tasmota. I'm able to pull temperature into HC3 quickapp variable using MQTT broker. The problem is, that I can not use that temperature in the HC3's Climate zone as reference temperature sensor for my zone (i can choose only from zwave devices).
Is there any solution for that?
Thank you
Max
8 answers to this question
Hello @Max Cerny, it's probably because your QA's type isn't a temperature sensor. I've checked and my ESP8266 temp sensors are available in the list of room main sensor.
Try to creat a new device with the correct type and copy past your code in it.
/monthly_2020_12/image.png.d951266cc95b486861340636377182dc.png" />
    Thank you @Tony270570 for your reply. Unfortunately this is not the case, the QuickApp is set as a Temperature Sensor
    Are your ESP8266 also QuickApps? If yes, could you share the code?
    /monthly_2020_12/image.png.47d00514580abdc63f43d45e22097d7f.png" />
    Stange, yes no problem but you'll need to adapt a bit, as the code is also managing other devices. What is your firmware version please?
    It's 5.061.36 (beta)
    Seems it's a bug in the latest FW - I can't see your QuickApp device in the climate zone neither...
    This is my QA file
    Edited by Max Cerny
    @Max Cerny hi, sorry i read you wrong in your 1st post ! You were talking about climate zone, and i was answering about room setup where you can default temp,humidity.... sensor. My bad sorry for that.
    But What are you trying to achieve? In the climat zone only thermostats are available, even zwave temperature devices are not there.
    or i have understand you wrong again :)
    Hi @Tony270570, I’m trying to use the cheap Sonoff device with Tasmota as a temperature sensor for fibaro heat controller.
    I am able to get temperature from the sensor to fibaro quick app as a variable - but i don’t know how to put that in a climate zone configuration in HC3.
    What is repported in climat zone are the temperature reported by FGTs(heat controlers), Only FGBRS-001  fibaro probe sensor can be linked to the FGT. This device is done to to get more accurate temperature.
    It will not be possible to add ny other temperature sensore to FGT except that one. It's not a bug but it's by design. So when you're likink this probe to an FGT, it's used  by your climate zone.
    So what you are trying to do is unfortunatly not possible i'm afraid :)
