Question: how to write RAW data to tcp socket with QA LUA
Joep
Hello, I found a project who reverse engineered the Wi-Fi protocol from the Mertik controller connected to my fireplace. Yeay! ?
With the following (simplified) NodeJS code I can send the standby command to my fireplace:
I know how to open a socket in HC3 QA but I don't get how to convert the message to a RAW buffer.
The JavaScript line does it with Buffer.from(prefix + msg, 'hex');
Does some LUA god know how to convert the message in QA LUA for the HC3?
6 answers to this question
5 bucks! :D
ocal hostname = "192.168.1.1"
    local port = 2000
    local tcpSocket = Net.FTcpSocket(hostname, port)
    wr, err = tcpSocket:write(
      string.char(0x21, 0x89, 0x01, 0x50, 0x57, 0x31, 0x0A)
Edited by 10der
  • Thank you very much! (gives 5 bucks) :)
    But the msg is variable, I have to input different values for different settings.
    The problem is how to convert it in LUA to your local buf = representation.
    Like this?
  • @10der and @jgab thank you very much for your help! This works! Now I can create a QA for my fireplace.
    I also got this tip this morning which works also:
    @10der: where are you on Discord? :)
    25 minutes ago, Joep said:
    Discord
    well, I take offense :D
    (joke, I am was busy with doing my current fintech project)
