QuickApp - Enphase Envoy monitoring
twanve
ENPHASE ENVOY MONITOR
  • This Quickapp retrieves; wattsNow, wattHoursToday, wattHoursSevenDays and wattHoursLifetime from the local Enphase Evoy (S ore Metered)
  • In the QuickApp labels wattHoursToday, wattHoursSevenDays and wattHoursLifetimes is shown
  • The wattsNow is shown in the top (under the sunpanel icon)
  • data refresh standard every 10 seconds, but Enphase Evoy update every 15 minutes (at this moment, but can change after software changes by Enphase)
  • Tested with:
  • Envoy-S-Metered-EU
  •  Softwareversion: 5.0.54
  • HC3 | 5.100.22
Version 1.1 (03th April 2022)
  • New download file, QA as Energie meter
Version 0.3 (26th January 2021)
  • bug: for HC3 5.051 users are not both values vissable. This QA copies to Multilevel QA
  • Change in Variable possible:
  • ShowData: 1 --> Top: wattHoursToday | bottem: wattHoursSevenDays (default)
  • ShowData: 2 --> Top: wattsNow | bottem: wattHoursSevenDays
Version 0.2 (22th January 2021)
  • Initial version
Variables (mandatory and automaticaly generated):
  • IPaddress = IP address of your local Enphase Envoy
  • Path = Path, normally "api/v1/production" (don't changes unless you know what you are doing)
  • Interval = Number in seconds, the Enphase Monitor normally is updated every 10 seconds
  • debugLevel = Number (1=some, 2=few, 3=all, 4=simulation mode) (default = 1)
  • Example content Json table
  • { "wattHoursToday": 5480, "wattHoursSevenDays": 21271, "wattHoursLifetime": 4122447, "wattsNow": 0 }
How to install:
  • Open the Configuration Interface
  • Go to Settings > Devices
  • Click  +
  • Choose Other Device
  • Choose Upload File
  • Choose file from your computer with .fqa
Vissable:
  • On top, "wattHoursToday" (this value reset every day to zero at 00:00 hours)
  • bottom (log) the 7-day "wattHoursSevenDays"
Edited by twanve
  • Like 5
@SmartHomeEddy
Great, thanks! I will test it.
I looked into your P1_Monitor QA, and I think I need the function where you calculate the "gross_consumption" (QuickApp:consumption).
BTW, what's the difference between fibaro.****** and hub.******?
Edited by _Wilco_
14 minutes ago, SmartHomeEddy said:
That's it, just what I needed. Thanks!
How do you get this information? Is it somewhere documented?
I think this specific property “rateType” I saw in the discusions about the new energy panel when we were modifying the QuickApps to fit the new energy panel. You could find all properties of a device in Swagger (“get device object”).
None , old version versus new version.
Indeed. You don’t have to use the api.put near the end. That is the routine to insert the sum in (spare) device.
Also take a look at the QuickApp:eDevices() to get all Device IDs which measure Energy Consumption. That is done once at startup of the quickapp.
Thanks for this QA, it works for me!
But is it possible to create different childs?
Every data variable into a different child. In this way, the current solar power is also visible in the Yubii app (production).
Who can help?
On 9/25/2022 at 5:38 PM, twanve said:
Strange, from this QA never a Error seen. Reboot the Envoy en check....
I have the same error...
  • Strange, no problem at my side.
    What error you get?
    What error you get?
    Receive no data at all. When i try to go (ip)/api/v1/production then that page is not available (error http 501).
    strange, I tested now and get my data;  envoyIP/api/v1/production
    Try also EnvoyIP/home
    Are you sure to use the correct IP adres to the Envoy, try to ping this adres with dos command or terminal (Mac)
    When i go to /home I receive a login screen from Enphase. On that page i have to enter a token.
  • Witch Envoy you have..?
    look
    for the admin login options for Enphase products
    I have an enphase envoy S. There is no possibility to enter username and password. I do have the token and then I can login. Is it possible that the firmware version on my Envoy is the reason?
    My Envoy: Envoy-S-Metered-EU with Softwareversie 5.0.54
    I think you on software version 7.0.88
    A search on the web, EnPhase deliver the new Envoy's with firmware 7.xxx. It's not possible anymore directly call the API local for you data without a token.
    So conclusion; my QA don't work with this new Envoy version....
    Look
     for the explanation (it's Dutch)
    For now, I don't update my Envoy from D5 -> D7, it seems very difficult to generate this token for Domotica.
    Sorry I can not help at this moment.
