Damir Popovic 0
I have several Fibaro Buttons attached to HC3 and all but one work as expected.
First on all of them whatever I do I have problem to see whether there is action set on particular event. For example when I go in configuration and set scene on +1 event when I come back to same screen it is always empty. I mean there is no scene title next to +1 icon. It is not huge problem because button works and activates exact scene when I press button. On HC2 it was obvious in the user interface that particular scene is set on particular event.
Second problem is related to particular button. Whenever I set scene to particular event in configuration and wake button, it works only first time when I press it. After that in UI I see only message "Device is awake" and "Transfer OK" but button doesn't show +1 in user interface. I can repeat process as many times as I want and it is always the same. First time works and after that I see only these messages "Device is awake" and "Transfer OK".
When it failed to work with scenes, I tried with associations. To be honest associations would be better choice for me but I have problem with them too. I'm not sure that I understand how these associations should be set and how configure them for +1 or +2 event.
I did soft reconfiguration of the device several times but it didn't help.
Anyway, any advice should be appreciated.
I've always had issues with buttons on my installation but ever since I migrated to HC3 it became very annoying.
4 answers to this question
