I would like to propose adding the feature userLabel to the Conditions / Triggers this way a user could find out what was the trigger event that triggered a scene where multiple conditions are present, simply:
example:
  conditions = { {
      isTrigger = true,
      operator = "match",
      property = "cron",
      type = "date",
      value = { "00""22""*""*""*""*" },
      userLabel = "time22"
      isTrigger = true,
      operator = "match",
      property = "cron",
      type = "date",
      value = { "00""07""*""*""*""*" },
       userLabel = "time07"
      isTrigger = true,
      operator = "==",
      property = "sunrise",
      type = "date",
      value = 0,
      usrLabel = "Sunrise"
      isTrigger = true,
      operator = "==",
      property = "sunset",
      type = "date",
      value = -30
      userLabel = "Sunset -30mins"
  operator = "any"
Then the scene code:
local label = json.encode(sourceTrigger.userLabel)
local myString
function stripChrs(myString) -- You need this as the sourceTirgger.* always returns ""
    newString=string.sub(myString,2,string.len(myString)-1)
    return newString
label = stripChrs(label)
if label == "time22" then -- Don something
