API request :last value from device
Hello everyone,
I'm trying to request the last value from temperatureSensor from the API of My HC3 (firmware 5.061.36 (beta) )
When I send :
I got a result like this (I trunck it, because of long answer) :
The field I'm looking for is created (1612636394)
As I've understood, the value is a timestamp that can be decode as "6/2/2021 à 18:33:14" (I get it from the web site :
 ). Ok fine, so the value seems to be 20.6 C from the 6/2/2021 at 18:33:14
My problem is that this is not the last value from my sensor ! I've got lots of other values (around 24 by days)  from this timestamp and now (the 8/2/2021).
Is the created field value a timestamp ?
How can I get the last value from my sensor ?
Every help is welcome.
Alex.
5 answers to this question
Maybe i did not understood the question very well, but the last value reported to the controller is the value.  Now as it is a battery operated device, it only transmits the value when it wakes up or when there is a change as defined in the parameters. So one way would be to modify the parameters of the device to send the value at a smaller change (default is 0.5 Celsius i think).  Another would be to have the sensor report the value more often.
Both of these options would drain the battery pretty fast. You could however solve that by connecting the sensor to DC power.
You have modification stamps per property of the device. .created is when the device was created, and .modified when you updated the configuration of the device.
To get the modification of the 'value' property of device 22
curl -X GET "XXXXXXXXX/api/devices/22/properties/value
returns something like:
{modified = 1612848831, value = true}
where modified is the last time the HC3 changed the  'value' property for device 22
Intriguing question, and I wonder if we are observing a "bug" here. When I look at my Fibaro Mobile App on Android, the "last modified" also often does not make sense. I don't care enough to investigate but I can say for example a motion sensor says "changed last week" while I'm 100% sure a motion scene was triggered right now. It might be a red herring but this is weird IMHO:
They are identical and as OP said it is "Sat Feb 06 2021 19:33:14 GMT+0100 (CET)"
@AlexPeret is that, by any chance, the last time you've rebooted your HomeCenter? Or last time you've made a back-up?
    @petergebruers : Yes you're right, this timestamp is more or less the time I've reboot my HC3 (nothing to do with the last backup date). Strange that it is return with this request... I said more or less, because  I can't remember precisely when I reboot my HC3, but that make sens.
    @jgabYou got the point. The request you gave return the last date (and value) from the device ID I want.
    By the way, where did you get this request from ? Because it's not documented in the Swagger interface (or did I miss it ?)
    You're right, it's not documented. It's been around since HC2 - and I believe it was documented in there -  it's the only way to get the modification date from the API so we have to hope it stays...
