a native integration Home Assistant and HC3 (MQTT Discovery)
hater
hi!
just for testing.
simple integration with HASS.
change MQTT server address and all* your devices now in your HASS
disclaimer:
1) alpha version.
2) only for ZWave devices
3) now supported only "Binary sensors / Lights / Sensors / Switches"
4) has minor bug with dimmer devices
Thanks to:
Peter for conception, testing and what he still tolerates me :)
Jan for fantastic fibaroapiHC3.lua
Tinman for sha* lib
14.04.2021
all lighting switches (interface lighting) now marked in HASS as "lighting" and you can simple grab this devices.
HC3 configuration
HASS:
check is installed
Appendix
RTFM:
Edited by hater
  • Like 5
14 answers to this question
I have this working.
I just wondered are you looking at the reverse at all?
Either importing devices using the MQTT discovery protocol (which HA doesn't support for export of devices)  or using HAStatesSream or the API to discover devices in HA and importing them to FIbaro?
PS Just for info this code requires HA has the LWT topics enabled.
Edited by xAPPO
  • @xAPPO sorry, I am lamer here ?
    just setuped some years ago HASS and only right now I can start working with it.
    Plus Peter ( petergebruers  ) is mentoring me cuz old integration did by him
    You mean, exposing all "states" and "events" originating in HASS to HCx? No, I am not looking at that at all.
    If you are only interested in Zigbee, this might do what you want (and does not need HASS)
    At the moment, I cannot get to the FQA because the "marketplace" is down, "Error 522"
    Yes , that's what I meant.
    Perversely although HA promote their MQTT auto discovery format they don't support it for export of their own HA devices.  Hence you have to use HA Statestream or their API.
    I wrote the HA > Hubitat integration and so I may take a look at doing this for HA > MQTT and then onwardly MQTT > HC3 with auto discovery. One for the project list.
    Kevin
  • UPDATED: all switches they has lighting interface now marked as is_lighting_device
    Very interesting topic :)
    I wonder if it is possible to do the reverse:  MQTT autodiscovery on the HC3 - to import stuff from a LAN MQTT broker.  I have about 70 devices on a broker which i would like to get into HC3 but setting them up one by one is ?
  • Clear all HC3' HomeAssistant entities
    Edited by hater
    Hello
    I ha e download the quicapp and when I put in all the credentials
    I get an error in hc3
    Mqtt error code"2"
  • On 7/31/2021 at 9:32 PM, nisrani said:
    Hello
    Mqtt error code"2"
    2 - not found,
    On 4/3/2021 at 8:36 PM, hater said:
    Hello
    What do You Mean
    Hello
    thanks For The replay
    But i don t know what You mean
  • 14 hours ago, nisrani said:
    What do You Mean
    Hello
    wrong MQTT server IP address or / and your MQTT server password protected.
    Hello thanks For The replay
    but in The broker log i see that mime Fibaro Ip adress try to Connect but than The Messages disconnect come
    and i did nog set-up a usrername of password For The broker
    On 8/3/2021 at 3:39 PM, hater said:
    2 - not found,
    Hello thanks For The info
    i have added A username and password in mqtt and know it works
    Yo @hater
    Can you maybe help me with something, i'm trying to get your quickapp to work. But i get some error
    [31.12.2022] [10:59:38] [ERROR] [QUICKAPP499]: Error: {"code":113}
    I'll am probably doing something stupid, i just changed the IP in the var's..what can go wrong :)
    I've setup MQTT in HA, but this is with a user/pass login. Do i need to make a seperate user without credentials ?
    If so, how do i do that.because when i add a user to HA, it needs the pass and username field to be filled in.
