Hi there,
I have HC3 and band new Walli Controller which I want to add it as secure. I need to control FIBARO Double Switch 2 which is in secure mode already.
Every time I try to add the Walli Controller, it adds the device to HC3 and the Walli Controller lights up as green. According to manual, it should light up as magenta when it was added as secure device and green in non secure mode.
Quote
Adding result will be confirmed by the Z-Wave controller’s message and the LED frame:
1. Green – successful (non-secure, S0, S2 non-authenticated),
2. Magenta – successful (Security S2 Authenticated),
3. Red – not successful.
I tried this numerous times and I also tried to hold the Walli Controller 3-5 cm from the HC3, but no success.
Any ideas?
2 hours ago, Ahmed Al Hafoudh said:
Hi there,
Any ideas?
did you thick the box on hc3, adding in secured mode?
according to the manual:
. If you are adding in Security S2 Authenticated, input the underlined part of the DSK (label on the box).
I'm sorry, can not help you if this is not working
i don't own any of the walli devices and i am certain i never going to buy them.
At the moment, HC3 only does S0 security, it does not do S2 yet. So "lights up as green" is correct.
