Error 597 when trying to properly set home location
l-i-n-k
It’s unclear to me if setting the home location really works…
- System build: 5.030.45
- the map doesn’t up
- after each letter I edit in the address the Error 597 message appears
- I do have some lat/log values that might be correct
Any similar experiences?
Your firmware is old. Best way is to upgrade to more recent firmware (log on locally to do so)
  • Issue solved. The error message is confusing and should be revised!
