    This will check of the activeProfile==1 every morning at 07:00 and if so turnOn the device 576
    In a simple case like this it turns out that one can post a lua function instead of an event - this means that we don't need the event handler
    So, fibaroExtra have had code for a cron function. Just added it to v0.943
    The example can then be written as
    The cron string has syntax
    There is a small bug currently that if you want to match all years leave that last parameter out - don't use '*' fixed
    Thank you very much.
    I updated fibaroExtr to 0.945 to fix a bug with cron. I also improved cron so all scheduled cron jobs share the same timer loop.
    This makes it very efficient to schedule several jobs in the same QA.
    Ex.
    Hi  jgab
     Thank you for everything, the implementation of the cron2 function and much more. So far I can't do much with the quick app I'm better at writing scripts.
    Thanks for the help and patience. ["01:36 * * * *"even that fits it works.
    01:36 is the same as 01-36, dvs all minutes between 00:01 and 00:36.
    I would not use fibaro._postSourceTrigger that is for internal use only. Use fibaro.post(ev[,time])
    A tip, have you tried the
    to develop the QA?
    It saves me a ton of time when developing and is the way I test peoples code when I help out in the forum.
    It's compatible with fibaroExtra and everything else you need to do when developing a QA.
    I test your code like this
    I set offline and speed and get an output like this
    Oh, btw. use fibaro.cron. fibaro.cron2 will be deprecated soon.
    Hi
    I did not manage TQAE emulator.
    Where can I look up this time format example "sunrise -10" and other. I would like that this time format like this "20:15" is supported, it is easier to read.
    01:36 is the same as 01-36, dvs all minutes between 00:01 and 00:36. probably that's why my mistake???
      ["01:03 * * * * "] =             "ActiveProfile",
      ["01:04 * * * * "] =             "Home",
    Debug:
    [03.07.2022] [01:03:00] [DEBUG] [QUICKAPP592]: Test {"type":"cron","datum":"01:03","timer":"ActiveProfile"}
    [03.07.2022] [01:03:00] [DEBUG] [QUICKAPP592]: Test {"type":"cron","datum":"01:03","timer":"Home"}
    [03.07.2022] [01:04:00] [DEBUG] [QUICKAPP592]: [Timer:13 01:04:00 07/03/22]
    [03.07.2022] [01:04:00] [DEBUG] [QUICKAPP592]: Test {"type":"cron","datum":"01:04","timer":"Home"}
    If I enter these two timers in my schedule like this, I get both triggered in the debug when the first one is triggered and then only the last one when the timer is triggered.
    In cron format (
    20:15 (15 min past 20) is expressed as
    "15 20 * * *"
    sunrise -10
    is my own extension. The idea is that we use the first field, the minute field) for sunrise or sunrise (that includes the hour) and then we use the hour field for an offset to the sun time.
    OK. I solved this for myself. Just swapped the h with m.
    I have one more question
    What happens internally with the set cron can you delete them or is deleted with the init or restart the new set when changing in the shy the old ones?
    Thank you
    Quote
    schedules = {
      ["sunrise -10 * * * *"] =       "sunrise",        -- 10min before sunrise every sunday in the last week of the month ["sunrise -10 lastw-last * 1 *"]
      ["sunset +10 * * * *"] =        "sunset",         -- 10min before sunset every sunday in the last week of the month ["sunset -10 lastw-last * 1 *"]
      ["45 20 * * * *"] =             "ActiveProfile",     -- every 10min starting at 0 on Mondays and Wednesdays ["0/10 * * * 2,4 *"]
      ["01:15 * * * *"] =             "Home",              -- every 10min starting at 5min on Mondays and Wednesdays ["5/10 * * * 2,4 *"]
    for scheduleTime,scheduleTimerName in pairs(schedules) do
        if scheduleTime:match("[:]") == ":" then
          local h,m = scheduleTime:match("([0-9][0-9]):([0-9][0-9])");
          x = scheduleTime:gsub( "(:[0-9][0-9])", ":".. h);
          scheduleTime = x:gsub( "([0-9][0-9]:)", m.. " ")
        print(scheduleTime)
    Edited by parip69
    Everything is cleared when the QA starts/restarts, but your init or other code will just register the cron "jobs" again...
    While the QA is running, you can delete an existing cron job with fibaro.removeCronJob(str) where the str is the same used for registering the job.
    • 3 weeks later...
    Hi. Unfortunately, it doesn't work with multiple variables??? With device, yes.
    Quote
    fibaro.event({type='device',id={509,44,146,143,139}}, function(env)
        print(env.id)
      end)
    fibaro.event({type='global-variable'},name={"var_1","var_2"}, function(env)
        print(env.event.name)
      end)
    Thank you
    Thank you
    It should have been
    But no, it doesn't. I could add it but it requires special code, and there are so many types of events that one could add support for... Allowing multiple device IDs was a special hack to be backwards compatible with some code I wrote years ago (EventRunner).
    However, fibaro.event always allow for a list of event patterns.
    or you could trigger on all globals and then check the name
    or if the variables have a commonality in naming (like starting with "var_")
    '<>' is the match operator that will take the name, and do name:match("_name") and if it returns true it's a match.
    The most efficient rule is the first as it will find the right handler with a single hash lookup of the globals variables name. The two after needs a second test after the right handler is found.
    However, in practice the time difference is of little importance (milliseconds) so the taste should decide.
    Thank you very much, the first example is to my liking.
    Hallo
    Bei jedem Drücken einer der Tasten erscheint diese Meldung, "[object Object],[object Object]" siehe Foto.
    Danke im Voraus.
    Edited by parip69
    Eh, you need to post in English - my German is really bad....
    I'm not sure what your problem is but it seems like you try to set the label to something that is not a string.
    If you use QuickApp:setView(<element>,<field>,<value>) it will automatically make a string out of <value>. If that is a class object it may look like in your example....
    Do you have some code to share where you update the labels?
    Hi
    Each time you press one of the buttons, this message appears, "[object Object],[object Object]" see photo.
    Thanks in advance.
    "updateView" quick app fibaro does not update?????????
    Edited by parip69
    On 7/29/2022 at 5:13 PM, parip69 said:
    Hi
    Thanks in advance.
    There is a bug in the Web UI for HC3 that doesn't always update the labels etc when they change - we have to wait for an update.
    Your problem I can't see what it depends on - never seen it before.
    If you change your self:setView to the "standard" self:updateView, does it work then?
    • 3 months later...
    @jgab
    Trying to rid of onAction and UIEvent printing by using
    Indeed, onAction does not printed anymore, but UIEvent continue to be shown on debug console!?
    Might be it doesn't go through print function?
    5 hours ago, cag014 said:
    @jgab
    Yep, they seem to have been doing it "right" and moved it to trace. Will update soon with fix. (would be nice if they did their "system" logging consequently...)
    Ok, fixed onUIEvent in latest fibaroExtra (v0.954)
