    4 hours ago, Neo Andersson said:
    @jgab Jan is there a way to retrive all the existing cronJobs ?
    I see in fibaroExtra that they are stored in a local jobs table. Can we somehow get them?
    No, not at the moment.
    You could add
    and you will have access the jobs table.
    The key is the cron string you register.
    You could add
    thanks
    @jgab Jan , do you have any clue, where to look for the reason that fibaroExtra loads twice?
    I have tried everything system restart, rebuild QA, delete fibaroExtra, reinclude etc
    Every time the QA gets saved, it loads twice
    /monthly_2024_04/image.png.89eb255d8e57760d49dec1da4b1c82fb.png" />
    Edited by Neo Andersson
    @jgab Jan, fibaroExtra utils.remove is not working ?
    throws error
    /monthly_2024_04/image.png.d6c045785a2c9198f5f7df1a5d2dfb57.png" />
    throws error
    I don't think there is an utils.remove (at least not since over a year ago)? Where did you see the reference?
    There is the Lua built-in table.remove(tab, index) and then in
    fibaroExtra there is the added
    table.delete(value,tab)
    that looks up the first instance of value in tab and removes it. (I know, logically the arguments should be swapped...)
    @jgab Jan, i have tested using different version of fibaroExtra..It seems that only the latest v0.964 is loading twice. Check this log, this is the testing with v0.961 and v0.964. In first case it is loaded only once
    /monthly_2024_04/image.png.4715912de26eb729a9c94adc60c9c87a.png" />
    Will test tomorrow. Been at a rum tasting session and should not touch code…
    v0.964 didn't load twice for me.
    Which gitrepo are you getting the code from? Seems fibaroExtra is available both in TQAE/libs and fibemu/examples....
    Can you produce a QA with fibaroExtra that loads twice and post to me? Best a minimal version without dependencies to a lot of devices so it's difficult to run for me... The one you tested in your last post was it a very complex QA?
    I have copy pasted it from forum link.
    Yeah this is what drives me crazy. The Qa from the last post was a simple tester QA nothing in it. As you can see, it was loading twice the fibaroExtra in one version and not in the other. However, now i can't reproduce it with this small tester, only with the big one. Here should be something happening, becuase yesterday I was able to reproduce this with a simple test QA (that you see on the attached pic, QA with id 1618 ), it was a simple tester QA, nothing in it, and i first tried with 0.61 version and the second attempt was 0.64 version. Now i have tried again, and this simple QA doesn't show double load now. However, the bigger QA still keeps loading twice, and in that QA it happens with other versions of fibaroExtra too. I am pretty lost here, because definitelly something makes the QA load twice. It also happened earlier with other QAs, but at this moment i can't reproduce it with just s simple test QA. Where the hell can this double load come from? The complex QA is pretty complex, but nothing out of ordinary. And even if it was, is there anything that can cause fibaroExtra to load twice? What to check? I am pretty sure i will catch it again with  other QAs too in the future, becuase this is not a new thing. This was happening earlier too (i think i wrote to you about this a few times)..I have no clue what to do..
    Quite complex, but it can run on its own. No need to set anything. It created a ROOMLIGHTDATA global variable at first, and then ueses it to manage light, pir, luxsensor events according to users choice. So here is what i did to reproduce. I grabed the complex QA, deleted everything from it. Nothing there just the onInit function and fibaroExtra file. And woala..still double load.
    Attaching the QA..
    19 hours ago, Neo Andersson said:
    Attaching the QA..
    Yep, there is something fishy going on here. I'm a bit busy today but I will dig into it as soon as possible..
    Ok, it actually doesn't seem to have anything todo with fibaroExtra (besides fibaroExtra being a file that prints out the log message every time it is loaded)
    This file with fibaroExtra replaced with a simple print line also loads twice.
    Install the QA and do a trivial edit (add a space) to both main and fileB so both tabs are open in the Device Editor.
    and then save. We get a log like
    So, it seems it kind of reloads all open files twice. After that, even if we edit just one file and save both files are reloaded twice again. (sometimes just one file is loaded twice)
    It is connected to the editor because if we exit the editor and do something like add a quickAppVar and save (which cause a restart) it only loads the files ones.
    fibaroExtra kind of adds a bit of complexity as it hijacks the QuickApp.__init function, so I think it's because of that we only see fibaroExtra load twice and not main.
    Is it dangerous? Well, it cause unnecessary restarts of the QA which can make cause&effect look strange if you do something in :onInit()
    So, in your case @Neo Andersson, it's not fibaroExtra that is loaded twice, it's the editor that loads the Lua file(s) twice. Will it cause problems? I don't think so, but I'm not 100% sure...
    Oh, one last thing. It seems to be related to how many UI elements we have. I haven't been able to reproduce the behaviour with a QA with less buttons then in the included example - but I don't know what is the cause & effect here...
    Yes, i was a bit afraid of that kind of answer. It is again something that i have to turn to fibaro support, and i am 1000% sure this question will never ever be answered or solved. Probably this problem is something similar to that other regarding missing button callback function warnings. It happens quite often, that when user presses quickly a button in a QA that has many control elements, we got a warning in WEB interface, that the button doesnt have callback function defined, what is not true..so it is probably originated from some similar problem soruces. Never mind Jan thanks for looking at it..I just hope, this wont harm anything, because there is a lot of QAs that are using complex UI setups, fibaroExtra etc..hopefully this will not affect memory or something..Thanks again
    @jgab Jan, i have seen your answer on other topic regarding timers. There is a long lasting concern of mine, when i dynamically create events, cronjobs or some other timer related stuff, It seems to me that my system is getting day by day using more and more memory.
    So i always take care when I re-post and event, or re-set some cronjob to first delete the old ones, but seems to me still, that timers numbers are increasing all the time.
    Using this approach, to keep track of timers
    will keep track of fibaroExtra timers too?
    Usually i follow this approach to first remove existing events if it needs to be recreated dynamically with some changed ids or whatever
    So using the listTimers apporach will list all running timers. even the ones created by fibaroExtra?
    EventHandlers themselves don't use timers - they are just a pattern and function stored in a table.
    When we post events a timer is started (even when time is 0) but they terminate when the eventHandler is invoked.
    cronJobs, the last version, only have one timer that every minute check if any con_string is up for execution.
    No, the listTimers approach I posted yesterday is not compatible with fibaroExtra, but it gave me the idea to maybe rewrite that part of fibaroExtra....
    • 3 weeks later...
    @jgab Jan, i am having issues using fibaroExtra cronjob...This is kinda important for me. I couldn't find where was the problem weeks..now i realized that the cronjob does not trigger twice if its created twice.
    so  it doesn't create two instances  for the same cronstring
    Iif i want to use
    This will print only Hello2,
    Can i just somehow get this working.
    In the QA structure i don't have the possibility to include both functions into one cronJob. The functions that should be run, are dynamically created by users, so it is not possible for me to handle them under one cronjob.
    Is there anything i can do about this?
    32 minutes ago, Neo Andersson said:
    @jgab Jan, i am having issues using fibaroExtra cronjob...This is kinda importnt for me. I couldt find where was the problem weeks..now i realized that the cronjob des not trigger twice if its created twice.
    so  it doesn't create two instances  forthe same cronstring
    Iif i want to use
    In the QA structure i don't have the possibility to include both functions into onw cronJob. The functions that should be run, are dynamically created by users, so it is not possible for me to handle them under one cronjob.
    Ok, I can fix it tomorrow...
    Okay, please dont forget, that i need to have some tracking possibility of cronjobs, as if user wants to delete some of them, we should not delete all of them with the same cronstring..
    Any kind of referencing would do the job..thank you..
    Ok, pushed v 0.966
    fibaro.cron returns a unique reference used to remove the cronjob.
    I'm about to make a rewrite of fibaroExtra, to incorporate some of the ideas that have come up lately.
    Try to make it as backwards compatible as possible.
    10 minutes ago, jgab said:
    Ok, pushed v 0.966
    Thanks Jan, well actually i have a lot lot of QAs based on fibaroExtra. Mostly those, where user needs their own dashboards. Many many dynamically created/deleted events.
    Every single one is using the event/time based functions. Posting, Cronjobs, etc. But hopefully they will be compatible,,I am awaiting the new fibaroExtra, because beside ER5 this is the most used helper tool in my work. And it is great.
    The only concerns i am having still is about the removed events as we talked about many times. For me it doesn't make any sense, that TIMERS ID numbers that are insisde an event post are increasing drastically after dynamic re-creating events.
    This is my major concern about all the things apart of some other things that we always work out somehow.
    In my logic
    Maybe i am overconcerned, but i am hunting the reason behind inexplicable inscreasing RAM usage day by day without addign any new device to the system. I am having even some unusual system restarts.
    All these symptoms are gone, when i don't use my QAs, so thats why i am hunting the reason down.
