Thenks Jgab, was understandable now :D but still got problems 😅
But now I think I need a loop to refresh the quickvars after a button events:
I got 2 buttons that sets:
Self:setvariable (Var1, 1)
and
self:setvvariable(var2,1)
but when I use my debug button at the end of the script I always get the results that the Quickvar had when the QA started.
function QuickApp:Debug()
self:debug("var1", var1)
self:debug("var2", var2)
is it a easy fix with the refreshstates?
On 7/16/2023 at 5:24 AM, jgab said:
Here we trigger on one variable and check the other...
May I ask if it is possible to check serval things? like trigger on var A and check Var B, C and D?
tried the "and" command but didnt work. if I have the syntax i think it is called right tho 😅
  • 6 months later...
@jgab
Jan, as i moved all my stuff to ER5, there are only a few things that i cant move, becuase they all need their own UI. They all use fibaroExtra.
The crucial thing is the subscribe functionality in fibaroExtra.
I am using it like this
What is the most convinient way to get similar approach without fibaroExtra?
Is there any way to pull out only this functionality from fibaroExtra and use it independenlty?
Or any other approach?
The new refreshState subscription kinda doesnt work for me../it doesn't work for custom events i think
Maybe you can assist a bit, how to transform the above example into the new refreshState subscription method if there is no way to cut out this funcionality from fibaroExtra?
UPDATE:
Maybe i would go for creating the Subscriber part in my ER5 QA, and there remains the publisher QA, that still requires fibaroExtra for publishing right?
Edited by Neo Andersson
    14 hours ago, Neo Andersson said:
    @jgab
    UPDATE:
    In ER5 there is fibaro.publish and fibaro.subscribe and there is also ER functions for them
    It should be compatible with fibaroExtra.
    Let me know if you have some problem with it.
    Okay, before i event start to test it...If i get it correctly this approach still requires the other QA to have fibaroextra right? How else would it be able to publish?
    Yes
    3 hours ago, jgab said:
    Yes
    @jgab Jan i got error
    This is how i set up the rule
    Yes, there were a couple of bugs after I moved the code to ER5. Pushed v1.04 with some fixes.
    • 1 month later...
    @jgab - how does one use fibaroExtra.lua in a QA? I pasted the latest code into a file in a new QA. Log immediately shows
    fibaroExtra.lua:2654: attempt to index a nil value (global 'debug')
    If i use the 'installer' method, I don't see this error. I'm trying to work out the difference me downloading the raw file from github vs your installer?
    Edited by gurpal2000
    @jgab Hello Jan, i am pretty sure we discussed it somewhere, but i canmt find the toopic.
    I have a table ROOMBLINDDATA
    I want to create event listeners dynamically for all the luxdevice ids held in that table and when that lux value changes, react with some action.
    I alos need to carry the room object itself to the handler so i can get all the info i need about the room. Can i pass the roomdata into event handler like in the example? Can i just use roomdata = room so it will carra the corresponding roomdata that i can use whe the event is triggered?
    You can't add (roomdata = room) to the event. The device event will not have that key and the match will fail.
    You can use the roomdata inside the function but there is a Lua issue...  the key and room loop variables will change for every loop so your functions will be left referring to the last room in the loop...
    What you do is that you assign room to a local variable inside the loop. That way every loop a new local variable will be created so that the functions get their own local variable.
    Jan this is not really clear...How to access then the room object data inside the handler? There is nothing that carries room object into the handler..
    Or did i get you wrong?
    Like every room object has several other data, forexample room.luxtreshold, how to access it?
    That variable 'room' is a local declared variable inside the loop and will be referenced by the handler function.
    The function creates a "closure" with existing local variables.
    @jgab Jan is there a way to use fibaro.cron() for sunrise/sunset ? maybe with help of fibaroExtra?
    Yes, the cron field for minutes and hour can be replaced with sunset/sunrise and minute offset.
    Ex.
    Ex.
    Jan it is complaining about sunrise and sunset
    using it like
    fibaroextra version
     fibaro.FIBARO_EXTRA = "v0.964"
    using it like
    fibaroextra version
    If you use sunset/sunrise the second field must be an offset, not *
    otherwise it would mean something like every possible offset to sunrise, which doesn't make sense...
    ahh okay thanks
    @jgab Jan i am creating event dynamically, on user button press. So if user chages something, the QA should recretae the events. I have noticed, that after recreating the events it triggers one more time on each recreation. Probably i need to cancel, or reset something behind the scenes i suppose. I assigned REF to the event, like ref = fibaro.event..etc and later used fibaro.cancel(ref) before recreating it, but seems that it doesnt help
    I have tried by referencing the event
    I have installed it from github link
    Still the same..doesnt help. It triggers as much times as the  createEvent function runs.
    I have tried using fibaro.removeEvent
    Reproduction:
    1. first run without button press and turning on 3038
    /monthly_2024_03/image.png.c3a946d5b253651ed2473f837d88a079.png" />
    2. after button press and turning on device 3039
    3. After button press and turning on 3038
    [QUICKAPP2772]: Device 3038 triggered
    UPDATE:
    I have managed to get rid of increiasing triggers after dynamically recreating an event using this function
    Is this the right apporach, or is there any more trivial one?
    OTHER NOTICE
    Also noticed that fibaro extra is loaded twice for some reason
    Can this be somethiing similar to ghosts in ER5?
    @jgab Jan is there a way to retrive all the existing cronJobs ?
    I see in fibaroExtra that they are stored in a local jobs table. Can we somehow get them?
