ppeterr 206
[edit] i think i should have placed it in the "Scenes and Interface" section, sorry for that.
So, i'm new, newbe, so...dont shoot me
I've been reading a lot, on this forum and elsewhere trying to get my Powerview shades connected to a zwave switch.
It seems to be much harder to manage then i was hoping for. My head spins around with all the information, code lines and such,
Also, none of the info i found seems to be complete. It is all like "do it in LUA", make a QA or a a bunch of code lines.
I hope to find some hints, or answers - help with that.
So, what i worked out:
- The 8 button fysical wall switch works.
- The powerview plugin works, and the scene's controlled from the hub work
The imported scene's dont work, and need i to make a QA or a LUA scene for that.
What i tried:
I made a block scene with the switch, and a HUE lamp, converted this to LUA
this is the "what if button is pressed" and it works.
The action part, i made this - but its wrong.
It gives this error:
10.07.2021] [07:00:40] [ERROR] [SCENE4]: (load):1: attempt to index a nil value (global 'Net')
I know there is a lost of writing about this on the forum but, I am totally lost in what to do, is this sort of the right way to do it ?
Should i do it with a QA ?
Edited by ppeterrtags
7
6
6
Jul 10
26
Jul 12
11
Jul 11
3
Feb 12
2
ppeterr 23 posts
tinman 7 posts
Symbiot78 6 posts
mike79 6 posts
Jul 10 2021
Jul 12 2021
Jul 11 2021
Feb 12 2022
tinman
regarding to the API both (depending on firmware version) should work, with upper i ( /api/scenes?sceneId=25173 ) or ( /api/scenes/25173) Probably the missing thing is content type, so try this o
tinman
you guys might try code above with QuickApp, the reason is very simply, Quick App and Scenes are using different http implementation. In scene i would normally use urlencode for everything
Symbiot78
@ppeterr - great.. Will test this. Just as an FYI .. the powerview module - which comes from Fibaro - that you can install ... I think I found the problem with it AND the
46 answers to this question
