    Because the emulator allows for the option to use asynchronous I/O it's easy to run "servers" in the background that the emulated QA can talk to.
    In particular it's useful for developing QAs that talk to external devices using TCPSocket.
    The emulator now contains a simple socketServer that can be started together with the QA in test and the socket server can easily be modified with more or less predefined responses to different commands. This is way easier than trying to develop/debug a similar QA on the HC3...
    Here is an example.
    The log gives (using the built-in Web UI to call the "turnOn" command)
    The TCP test QA is part of the examples provided in the TQAEexamples subdirectory.
    Tried implementing the TQAE - followed the
    but is stuck here. Is using ZBS 1.90 (newest)
    Thanks, that was a bug. wsLua was in my path so I didn't notice it was missing in the source I distributed. I uploaded the new version (you only need to update net.lua in TQAEmodule/)
    I'm still missing some files, I have a MQTT library, init.lua is there and not found but not the MQTT.lua
    Program starting as '"/Applications/ZeroBraneStudio.app/Contents/ZeroBraneStudio/bin/lua.app/Contents/MacOS/lua53" -e "io.stdout:setvbuf('no')" "/var/folders/nr/kj3y7bl10sj55ylrgdc7xw000000gn/T/.dTu9mo"'.
    Program 'lua53' started in '/Users/christian_nielsen/Downloads/TQAE' (pid: 6345).
    Debugging session started in '/Users/christian_nielsen/Downloads/TQAE/'.
    Program completed in 2.26 seconds (pid: 6345).
    TQAE.lua:281: Loading module TQAEmodules/net.lua:162: module 'mqtt' not found:
        no field package.preload['mqtt']
        no file '/usr/local/share/lua/5.3/mqtt.lua'
        no file '/usr/local/share/lua/5.3/mqtt/init.lua'
        no file '/usr/local/lib/lua/5.3/mqtt.lua'
        no file '/usr/local/lib/lua/5.3/mqtt/init.lua'
        no file './mqtt.lua'
        no file './mqtt/init.lua'
        no file './lua/mqtt.lua'
        no file './lua/mqtt/init.lua'
        no file '/Applications/ZeroBraneStudio.app/Contents/ZeroBraneStudio/lualibs/mqtt/mqtt.lua'
        no file '/Applications/ZeroBraneStudio.app/Contents/ZeroBraneStudio/lualibs/mqtt.lua'
        no file '/Applications/ZeroBraneStudio.app/Contents/ZeroBraneStudio/lualibs/mqtt/mqtt/init.lua'
        no file '/Applications/ZeroBraneStudio.app/Contents/ZeroBraneStudio/lualibs/mqtt/init.lua'
        no file '/Applications/ZeroBraneStudio.app/Contents/ZeroBraneStudio/bin/clibs53/mqtt.dylib'
        no file '/Applications/ZeroBraneStudio.app/Contents/ZeroBraneStudio/bin/clibs53/libmqtt.dylib'
        no file '/usr/local/lib/lua/5.3/mqtt.so'
        no file '/usr/local/lib/lua/5.3/loadall.so'
        no file './mqtt.so'
    stack traceback:
        [C]: in function 'error'
        TQAE.lua:281: in local 'loadModules'
        TQAE.lua:496: in main chunk
        TQAE_QA.lua:1: in main chunk
    Edited by ChristianSogaard
    P
    Sorry again. Need to include mqtt the proper way. I think I went through all the code so there should be no missing files anymore.
    Pushed new version to GitHub (only net.lua needed change)
    Thank you Jan
    But that didnt work for me
    tried updating the
     and that didnt work i started all over with
    -- Every file in one archive
    Program starting as '"/Applications/ZeroBraneStudio.app/Contents/ZeroBraneStudio/bin/lua.app/Contents/MacOS/lua53" -e "io.stdout:setvbuf('no')" "/var/folders/nr/kj3y7bl10sj55ylrgdc7xw000000gn/T/.T3Kvur"'.
    Program 'lua53' started in '/Users/christian_nielsen/Downloads/TQAE' (pid: 13977).
    Program completed in 1.69 seconds (pid: 13977).
    TQAE.lua:281: Loading module TQAEmodules/mqtt/init.lua:34: module 'mqtt.client' not found:
        no field package.preload['mqtt.client']
        no file '/usr/local/share/lua/5.3/mqtt/client.lua'
        no file '/usr/local/share/lua/5.3/mqtt/client/init.lua'
        no file '/usr/local/lib/lua/5.3/mqtt/client.lua'
        no file '/usr/local/lib/lua/5.3/mqtt/client/init.lua'
        no file './mqtt/client.lua'
        no file './mqtt/client/init.lua'
        no file './lua/mqtt/client.lua'
        no file './lua/mqtt/client/init.lua'
        no file '/Applications/ZeroBraneStudio.app/Contents/ZeroBraneStudio/lualibs/mqtt/client/mqtt/client.lua'
        no file '/Applications/ZeroBraneStudio.app/Contents/ZeroBraneStudio/lualibs/mqtt/client.lua'
        no file '/Applications/ZeroBraneStudio.app/Contents/ZeroBraneStudio/lualibs/mqtt/client/mqtt/client/init.lua'
        no file '/Applications/ZeroBraneStudio.app/Contents/ZeroBraneStudio/lualibs/mqtt/client/init.lua'
        no file '/Applications/ZeroBraneStudio.app/Contents/ZeroBraneStudio/bin/clibs53/mqtt/client.dylib'
        no file '/Applications/ZeroBraneStudio.app/Contents/ZeroBraneStudio/bin/clibs53/libmqtt/client.dylib'
        no file '/usr/local/lib/lua/5.3/mqtt/client.so'
        no file './mqtt/client.so'
        no file './mqtt.so'
    stack traceback:
    Debugging session completed (traced 0 instructions).
    On 10/11/2021 at 9:29 AM, jgab said:
    New version, v0.30.
    Lot's of bug fixes and a better web UI.
    Here is a short installation tutorial:
    Installation
    The source for the emulator is available at the Fibaro forum link or directly from my GitHub <
    > (It's a bit messy...)
    First time download the archive,
     and unpack it in a suitable directory on your PC/Mac/Linux.
    On Linux:
    On PC/Mac use suitable archive program to unpack the archive.
    Download ZeroBrane studio <
    Open ZBS and open the TQAE_QA.lua file
    Set project directory in ZBS to the current file, TQAE_QA.lua (Project->Project Directory->Set From Current File)
    Also set Lua interpreter to Lua 5.3 (Project->Lua Interpreter->Lua 5.3)
    Now, run TQAE_QA.lua (F5 in ZBS).
    The output will look something like:
    Note first that there is no connection to the HC3 - we are missing user,  password, and IP for the HC3.
    Secondly, note the WebAPI address. 192.168.1.18 is my machine, your IP address may be different. The port is 8976.
    Open http://192.168.1.18:8976/web/main in your browser.
    Goto [Settings] in the web page menu (upper right)
    In the right hand column "Settings file", fill in User ID, Password, and IP address for the HC3.
    Scroll down to the bottom of the page and click "Save"
    Hopefully there is now a TQAEconfigs.lua file with the HC3 credentials that the emulator can use.
    Go back to ZBS and stop the program (Shift-F5) and run it again:
    It loads the config file and doesn't complain that there is no connection to the HC3 anymore.
    Great we are up and running!
    Hello Jan,
    will follow your instructions to install the emulator.
    Unfortunely i fail on the first steps: My output on ZEROBRAIN is this:
    What do i wrong?
    You just need to press run again. The debugger stops at the first line of the code. See that little red arrow up to the left on the first line?
    First click
    Second Click
    third Click
    20 minutes ago, ChristianSogaard said:
    First click
    Second Click
    third Click
    I copied the MQTT lib into ZBS- and now it works.
    Oh, this was really difficult. I've uploaded a new version that hopefully makes it work.
    It may be an issue on windows machines due to different path separator in directory paths - let me know if you have issues on windows machines and I will try to fix it.
    i'm on MAC ;-) so a cant test on Windows, Sorry.
    I deleted the MQTT in ZBS and downloaded the package again. It works
    Thank you for all you assistance
    P
    New version, v0.30.
    Installation
    On Linux:
    Hi Jan
    Would you mind upload a version of iOSLocator.lua with TQAE integrated and fibaroExtra.lua for ZBS so i can start the trace why my iOSLocator.lua is not working? -I am so confused with TQAE, ZBS and the "old" fibaroapiHC3.lua...
    i ended up with this - but no luck
    _=loadfile and loadfile("TQAE.lua"){ user="xxxx", pwd="xxxx", host="192.168.xxx.xxx" }
    --%%name='Test'
    --%%id=99
    --%%quickVars={x=88,y=99}
    function QuickApp:onInit()
    --  modPath = "TQAEmodules/",
    _=loadfile and loadfile("fibaroExtra.lua"){
    --%%name="Test QA"
      self:debug(self.name,self.id)
      self:debug([[This is a simple QA that does nothing besides logging "PING"]])
      setInterval(function() self:debug("PING") end,1000)
      self:debug("y=",self:getVariable("y"))
      local n = 5
          n=n-1
          if n <= 0 then os.exit() end
          self:debug("PING")
          end,1000)
    ---------------------- Setup users -----------------------------
    local version = "V0.2"
    local USERS = {      -- Fill in with iOS credentials
     {name='admin', id = 2,  device='Dr. S iPhoneX', home=true, icloud={user='xxxx', pws='xxxx'}},
     -- {name='ad
    P
    1 hour ago, ChristianSogaard said:
    Hi Jan
    This  one  I use
    6 hours ago, jgab said:
    This  one  I use
    Thank you @jgab
    P
    Thank you @jgab
    Hi Jan
    i'm up running - thank you for all you help ?
    I found the error - you wrote.
    But its pwd and not pws :-)
    and in
    its - quickApp and not quickApp2
    P
    A new Updater QA that helps in updating QAs on the HC3. At the moment it only supports my own QAs but the mechanism is there to allow people to add their own QAs. The pre-requisite is that QAs are stored in GitHub and version are tagged. It blends well with the TQAE development environment.
    Great intro to the TQAE emulator <
    > by @Joep
    - thanks @Joep!
    • Thanks 2
    On 10/29/2021 at 10:36 AM, jgab said:
    This  one  I use
    Hi
    I have used the IOSLocator for some time, or it has been installed, and i started to look more into it, because i want to use it as GEOFensing.
    A minor Observation
    If the device='iPhone' name is 'silje :)' it dont work, and if I with same credentials uses 'Siljes iPad Pro' it works - so the parsing of the iphone name, can't handle the semicolon or the parentheses.
     -- {name='Ann',   device='iPhone', home=true, icloud="XXXX2"},
     -- {name='Tim',   device='iPhone', home=true, icloud="XXXX3"},
    /monthly_2022_01/2022-01-09_15-56-34.png.192c7edc724b8c824c16ce2dcccb27f0.png" />
    P
    Yes, it's a bit tricky how to match
    Think about the device name you configure iosLocator to be a pattern that should match the real device name.
    "iPhone Jan"
    matches
    "iPhone Jan" and "iPhone Jan (2)"
    Because it's a pattern it needs to conform to pattern rules. A pattern with just a ")" like in ";)" is malformed because "()" is used for pattern captures.
    You could specify your device as "Siljes %:%)" and it would match "Siljes :)". That is because % escapes pattern directives like the ")"
    It's the same rules as for
    Would that work for you?
