Controlling IR Based devices
Hi, apologies if i have posted this in the wrong section!
I have a projector screen, Sapphire - which works with an IR remote, it doesn't appear to have any direct control buttons on the screen casing.  Also, i have a projector in my room, again which has an IR control.  I would like to control both of these with Fibaro - is there a way (perhaps not directly, but using 3rd party products) that i can set Fibaro up to control these - for example, lower the screen and turn on the projector.
5 minutes ago, Petramg said:
Chápeš že já nevím co mi tu ukazuješ? Že nerozumím těm obrázkům, že nevím jak se píše lua, neumím to!!!!
moje ip adresa RM4 je 192.168.1.153  tak udělám fibaro.call(1948"learn""192.168.1.153"0x51da) a to dám kam?
Just a little reminder....this is a international section of the forum :)
5 minutes ago, ppeterr said:
Jen malá připomínka .... toto je mezinárodní část fóra :)
TRANSLATED Do you understand that I don't know what you're showing me? That I don't understand those pictures, that I don't know how to spell lua, I can't do it !!!! Iˇm sorry ppeterr
1 minute ago, Petramg said:
PŘEKLADY Chápete, že nevím, co mi ukazujete? Že těm obrázkům nerozumím, že nevím, jak se píše lua, to neumím !!!! Omlouvám se, ppeterre
1 hour ago, 10der said:
broad linkhub has method
function QuickApp:learn(ipAddress, deviceType)
so.
lets go
call from another QA
fibaro.call(1948"learn""192.168.1.51"0x51da)
as u can see device now in learn mode
tryin to pass some RC
yay!
JgBQAAABJpMTOBMSExITEhMSExITEhMSExMSOBM3EzcTNxM3EzcTOBM3EzcTEhMSEzcTEhMTEhMTEhMSEzcTNxMSEzcTOBM3EwAFGAABKEkTAA0FAAAAAAAA
@Phenix^^^^^^^^^^^^^^^^^
I did a QA TEST, in main I put fibaro.call (304, "learn", "192.168.1.153", 0 × 51da)? 304 is id TEST, 192.168.1.153 ip RM4 mini is it correct?
Class does not have learn function defined - action ignored
Edited by Petramg
przepraszam pan.
304
305...
ok. this ID should be installed broadlink hub QA
22 minutes ago, 10der said:
pánev przepraszam.
304
305 ...
OK. toto ID by mělo být nainstalováno broadlink hub QA
id number should be broadlink hub or QA? it's complicated for me... id broadlink hub is 303 and Quick app TEST 305.... fibaro.call(303,"learn","192.168.1.153",0x51da) paste main quick app TEST?
    lol - i noticed!  Thank godness for Google Translate
    Edited by Liquidchild
