Europino 0
Hello HC3 owners/guru's,
Is there anyone who can tell me what the impact is of a change of the physical location of a HC3 device?
Currently I am living in Europe (Belgium). I might have to move to Asia (Philippines) next year and want to bring my HC3 and re-install it there in my new house.
I see the following 2 potential problems:
Note: I experienced a similar problem (issue 2 above) when I moved around with my printer from Thailand to the Philippines a few years ago, as the ink cartridges are not interchangeable between the 2 countries and other regions..
I guess this is a question for Fibaro HC3 guru's or a Fibaro company HC3 specialist. Your help would be appreciated if you can answer my questions or can tell me how to contact a Fibaro HC3 specialist.
Thanks Leo
I used the below URL for my short survey.
URL:
EU 868.4 MHz, 869.85 MHz - Standard EN 300 220
PH 868.4 MHz, 869.85 MHz - Standard EN 300 220
