svaleb 5
I have asked support what this level change are for and, in my case, what they do to an eurotronic thermostat.
As I see it it is some kind of offset (?)
What does it do ?
How do I reset to normal/standard ?
It seems the thermostat is heating 1-1,5 degree more than usual stlill set to 16.
In fact I was just trying out what happened when I pressed it a cupple of times. I was hoping to get a message "you have now ...", but no.
I got a nice and polite answer from support...but I still dont understand where to get it back to normal.
"These arrows allow you to set a higher / lower value of the light intensity in the dimmer. If you want to set the default value again, you should set the full lighting value or the minimum value (on / off). In the thermostat, it changes the temperature. The default values are set by default in the schedule in the climate dashboard. Additionally, a square may appear in the case of roller blinds. is used to stop the lowering or raising of roller shutters"
/monthly_2022_03/image.png.884d71d9cb0cd8e43f2c720c34cbace3.png" />6 answers to this question
