I would like to share with you the solution below.
Z-TRM3 firmware 4.0
HC3 version 5.110.15
I have created a scene where the HeatIt TRM-3 should adjust the temperature for a set time.
Unfortunately nothing happens when a scene is created, see screenshot.
From the Quickapp it does work fine.
After some research with Swagger and ZeroBrandeStudio it show me that the wrong action is called from the scene.
Namely:
instead of:
In summary, the Lua below can be used to temporarily adjust the temperature and schedule. The argument string is also a bit different.
My device id = 43. This sets the temperature to 11.5 degrees during a period of 25 minutes.
I have passed this to HeatIt support, hopefully they will come up with an update.
Edited by RobLu
    Sorry wrong forum/group
    • 2 months later...
    Hi @RobLu , please, something new to HEATIT Z-TRM3 thermostat and override mode? HC3 scene still doestn work.
    Your code is working, but only for short time. After 1 minute is this override overwritten by HC3 schedule.
    Thank you
    Martin
    Hi, this is correct for Heatit thermostat:
    hub.call(604'setClimatePanelOverrideSchedule''{"setpoints":[{"value":20,"unit":"C","type":"Heating"}],"mode":"Heat"}''{"value":1,"type":"Hours"}''{}')
    Thanks @marbe
