http request 400
DavideB
Using code from other posts I am trying to invoke an external URL: for the time being I'm interacting with a simple RequestBin that is working perfectly fine.
The following code is always returning 400 in the success and never reaches the endpoint.
The output I see from the console is the following:
[20.08.2022] [18:27:15] [DEBUG] [SCENE5]: 400
[20.08.2022] [18:27:15] [DEBUG] [SCENE5]: 400 Bad Request
400 Bad Request
For context, I am able to connect locally and remotely to the HC3L and I can invoke RequestBin from the same network the HC3L is on.
After looking for solutions in other threads I think I am missing somethign very silly but also important.
Thanks in advance!
Do you have:
self.httpClient = net.HTTPClient()
somewhere in your code?
(see:
 or
Edited by SmartHomeEddy
  • Sorry for leaving out part of the scenario: from a LUA scene I am trying to invoke http endpoint.
    While I might explore the QuickApps concept, is it possible to use HTTClient in the action of a LUA scene?
    The whole action:
    Thanks!
  • FWIW following
     to create the QuickApp, then the GET/POST sample in
    , from the original LUA scene I can call
    Where 23 is the deviceId of the QuickApp, "invokeHA" is the method name in the QuickApp and 34 is a parameter value I pass to the method.
    The properly configured QuickApp is able to execute HTTP call to RequestBin --- solved
