The Radiation Monitor collects radiation levels from all available stations around the world and shows 5 nearest stations to your location and one station with highest current readings and one station with the highest 24 hour average readings. The QuickApp uses the location (latitude and ongitude) of your Homecenter to measure the distance to the stations and to get the nearest stations. The bearings in degrees from your location to the stations is shown. Next to the measurements, the five nearest reactors are shown. The languages English, French, Polish and Duth are supported.
Thanks to @Sankotronic for his work for his HC2 Virtual Device version and ideas.
The main device shows the nearest measurement μSv/h. There are Child Devices for:
  • Nearest sensor 24h average μSv/h
  • 2nd, 3rd, 4th, 5th nearest sensor measurement with the 24 average in the log text
  • Nearest maximum measurement
  • Nearest maximum 24h average measurement
The nearest five reactors are retrieved once at startup of the QuickApp or at the next interval if you click on the button.
Radioactive@Home is a Polish science project using the distributed computing capabilities of the BOINC platform. The main goal of the project is to create a free and continuously updated map of radiation levels available for everyone, by gathering information about gamma radiation using sensors connected to the computers of volunteers willing to participate in the project. Project is completely non-commercial, participating will be free of charge (excluding cost of detector) and the software will be licensed under the GNU General Public License (GPL).
μSv/h: The sievert (symbol: Sv) is a unit in the International System of Units (SI) intended to represent the stochastic health risk of ionizing radiation.
In land navigation, a 'bearing' is ordinarily calculated in a clockwise direction starting from a reference direction of 0° and increasing to 359.9 degrees. Measured in this way, a bearing is referred to as an azimuth by the US Army but not by armies in other English speaking nations, which use the term bearing.
The human population is continuously exposed to ionizing radiation from several natural sources (cosmic and terrestrial contributions). For most individuals, exposure to natural sources exceeds that from all man-made (artificial) sources combined. The man-made sources arise from peaceful (e.g. medical use, energy generation, and associated fuel cycle facilities, radioisotope production, waste management) and military purposes (nuclear tests and their fallout or radioactive release, nuclear explosions).
Radiation levels:
Green: Radiation up to 0.3 μSv/h
Yellow: Radiation between 0.3 and 0.8 μSv/h
Red: Radiation above 0.8 μSv/h
1.14 µSv/h - Shelter population
5.7 µSv/h - Evacuation of population
11.4 µSv/h - Issue Iodine tablets
0.114 µSv/h - Max daily dose == 1 mSv/year
Reverse Geocoding by Nominatim
Reverse geocoding generates an address from a latitude and longitude. The reverse geocoding API does not exactly compute the address for the coordinate it receives. It works by finding the closest suitable OSM object and returning its address information. This may occasionally lead to unexpected results.
/monthly_2022_11/radiation-monitor-1c.png.762783dcc152d2602bb666ee45869ef9.png" />
QuickApp code logics:
  • onInit() Initialise the QuickApp
  • getQuickAppVariables() Get all Quickapp Variables or create them
  • createVariables() Setup the global variables
  • setupChildDevices() -- Setup all child devices
  • loadMap() Get the webpage from
    (This is the main loop of the QuickApp)
  • extractData() Extract the data from the webpage source-code
  • geoDistance() Calculate the distance from the HC3 (QuickApp variables) lat/lon to the sensors lat/lon
  • geoBearing() Calculate the bearing from the HC3 (QuickApp variables) lat/lon to the sensors lat/lon
  • Check for the values to give the right dot colours for the sample and average measurements
  • Store the values of all sensors in a table and sort the table on distance
  • Run through the table to get the maximum sample and maximum average measurements. If there are more than one, get the one that is the nearest-by
  • updateIcon() Set the icon (colour) based on the sensor measurement
  • getCity() Get the cities and countries for the seven selected sensors from
    and store them in a table
  • updateLabels() Update the labels
  • updateProperties() Update the properties
  • updateChildDevices() Update the Child Devices
  • Return to the main loop loadMap()
Links:
  • Radioactive@Home Map:
  • Status servers:
  • Reverse geocoding:
    licence:Data © OpenStreetMap contributors, ODbL 1.0.
  • Nominatim Usage Policy (aka Geocoding Policy):
Variables (mandatory and created automatically):
  • latitude = Latitude of your location (Default is the latitude of your HC3)
  • longitude = Longitude of your location (Default is the longitude of your HC3)
  • language = Preferred language (default = en) (supported languages are English (en), French (fr), Polish (pl), Croatian (hr) and Dutch (nl))
  • interval = Interval in seconds to get the data from the Radioactive@Home website
  • debugLevel = Number (1=some, 2=few, 3=most, 4=all) (default = 1, debugLevel 4 is only recommended for solving difficult issues)
  • icon_refresh = User defined icon number for refresh status
  • icon_green = User defined icon number for values less than 0.3 μSv/h
  • icon_yellow = User defined icon number for values between 0.3 and 0.8 μSv/h
  • icon_red = User defined icon number for values greater than 0.8 μSv/h
  • icon_error = User defined icon number in case of an error gettng the data
Version 1.4 (6th February 2024)
  • Added extra check for an empty response in the address from Geocity (thanks to @Sankotronic from the Fibaro forum)
Version 1.3 (17th July 2023)
  • Added extra check for the right response from Geocity (in case of response {"error":"Unable to geocode"})
Version 1.2 (11th January 2023)
  • Added support for Croatian language thanks to @Sankotronic
Version 1.1 (9th January 2023)
  • Changed handling of negative values for dots and icons: if tonumber(num) >= 0 and tonumber(num) <= 0.3 then
  • Added a better translation for French (thanks to @fredokl)
Version 1.0 (5th November 2022)
  • Added the nearest five reactors to the labels with distance and bearing
  • Added a button to refresh the list of (five nearest) reactors
  • Added a warning at startup if the latitude or longitude differs from the setup of your HC3
  • Replaced the creation of the dots 🟢🟡🔴 to the labels, so no longer for all sensors
  • Added some extra notifications to the labels in case the website is down
  • Extended the http timeout a bit, to give the reverse geocoding some more time to respond
  • Added translations for new functions
Version 0.5 (29th October 2022)
  • Added translation to the Reverse API geocoding response (city and country)
  • Changed calculation of the bearings only for the 7 selected sensors, not all sensors
  • Optimized the code and added more structure by using multi file code (main, childs and i18n)
Version 0.4 (22nd October 2022)
  • Added six Child devices for the nearest sensor 24h average, 2nd, 3rd, 4th, 5th nearest sensor sample, the nearest sensor maximum sample and the nearest sensor maximum 24h average
  • Added icons based on sensor measurements to all Child Devices
  • Added translations for the labels and properties from English to French, Polish and Dutch. (Thanks to @ppeterr and @fredokl for help with the translation)
  • Limited the details of the response of the Reverse Geocoding with zoom=10 (address detail = city)
Version 0.3 (16th October 2022)
  • Added the City and Country also for worst sample and worst average sensors
  • Added all debug information and set the debug levels
  • Optimised the code
Version 0.2 (15th October 2022)
  • Added the City and Country for all 5 sensors, not only the first one
Version 0.1 (15th October 2022)
  • Initial version
Download the QuickApp here (download the file and un-zip):
or from the Fibaro Marketplace:
How to install:
  1. Open the Configuration Interface
  2. Go to Settings > Devices
  3. Click  +
  4. Choose Other Device
  5. Choose Upload File
  6. Choose file from your computer with .fqa
Icons thanks to @Sankotronic
image.png.69f69625580adda6e16fa2a12cf0b851.pngimage.png.34c11c6855da86a0ab686982678aea0c.pngimage.png.6170fc1e918407462f60261d0ef3ebc9.pngimage.png.b02b02f067cca39ea6e1971795241863.pngimage.png.61ed78e363bbafd8d3447f5308223746.png
Edited by SmartHomeEddy
  • Like 5
    10 minutes ago, ppeterr said:
    Your app functions wonderfull.
    Thanks, it was nice to work on with some different technique’s.
    There is a different map from the EU, with more sensors. But I can’t find a way to get the measurement from that site. I asked if they have an API, the don’t. And the way the site build up, is different.
    With a lot of help, we found a way to get the info from data form the EU site ?
    So there is something coming soon ...
    Great. QA works great!
    Thanks for sharing the code. It's very nice of you.
    @SmartHomeEddy
    I offer you a translation update in a more correct French if you want.
    Thanks for the translation @fredokl I will add it in the next version
    This is a very good idea.  I need some assistance though.  I've installed it to my HC3, but the sensors its displaying make no sense given my location and one of the sensors is displayed twice.
    My German PLZ is 14612 (pop it into GoogleMaps)
    Its bringing up sensors in Italy.
    Help?
    Hi @Gatriel thanks for the compliment.
    You can check the latitude and longitue settings in the quickapp variabels if they are yours.
    If not, you can change them to your location, or simply delete them so they are generated with the location of your HC3.
    Apologies ... talk to me like I'm an idiot. How do I do this? ?
    if you select the variables, then you find the quickapp variables
    /monthly_2022_11/B6CF0A01-AD36-4671-B3A9-7F7D34A4E381.jpeg.dec481ce6f41ef31ad562b1dfd58a9ed.jpeg" />
    Then you find the latitude and longitude variables
    you can change them by pushing the pencil icon, if you know your location in latutude and longitude.
    Or you can delete them by pushing the trash bin icon. The quickapp will make new ones for you, with the location of your HC3.
    Don’t forget to push “save” to make the changes definitive.
    Thank you.
    So its improved but I am still getting stuff in Italy (despite being near Berlin) and two sensors are displayed twice.  Any ideas?
    The labels show five nearby sensors, plus the sensor with the maximum measurement plus the sensor with the maximum 24 hour average.
    The measurement in Italy will be the maximum measurements, I guess.
    Can you share a picture of what you see?
    See attached.
    There are two sensors in Ruhland Germany.
    The sensor in Italy has the highest measurement for both current as 24 Hour average.
    Thank you.  Very helpful tool.  I like it a lot.
    Thanks.
    Have fun with it. Although, fun with radiation may be a bit odd.
    You can attach some notifications to it, just to be sure.
    It also raises some awareness, radiation is a thing of nature (and humans).
    On 11/6/2022 at 9:00 AM, ppeterr said:
    It works great, good job!
    What I do wonder, and that has nothing to do with your quickapp. When I look at the positions of the sensors, they are all quite far away from the reactors. The Netherlands does not even have its own sensor. I would have placed one near Borsele :)
    The Utrecht sensor is finaly back in production
    A new version is available. It is a small update, you can copy-paste the main.lua and i18n.lua files.
    • Added a better translation for French (thanks to @fredoki)
    • Like 3
    Hi @SmartHomeEddy ,
    Translation for Croatian:
    You might consider changing line of code that checks local variable language so that new languages can be added without needing to change main code:
    instead of
    I noticed that when I added Croatian language to the i18n code, but QA was still resetting variable language from hr to en.
    Thank you for another great QA! 👍
    Thanks Zoran!
    Indeed the main code needed to be changed if a new language was added. Was looking for a way to check the language code in the i18n translation table.
    Great solution, will implement it, thanks!!!
    Uploaded version 1.2 with the support for Croatian language thanks to @Sankotronic
    Changed the way the quickapp variable for the language is checked with the code from @Sankotronic
    So for now you have to copy-paste both the main and i18n file (but in the future only the i18n file if only a language is added).
