The Radiation Monitor collects radiation levels from all available stations around the world and shows 5 nearest stations to your location and one station with highest current readings and one station with the highest 24 hour average readings. The QuickApp uses the location (latitude and ongitude) of your Homecenter to measure the distance to the stations and to get the nearest stations. The bearings in degrees from your location to the stations is shown. Next to the measurements, the five nearest reactors are shown. The languages English, French, Polish and Duth are supported.
Thanks to @Sankotronic for his work for his HC2 Virtual Device version and ideas.
The main device shows the nearest measurement μSv/h. There are Child Devices for:
  • Nearest sensor 24h average μSv/h
  • 2nd, 3rd, 4th, 5th nearest sensor measurement with the 24 average in the log text
  • Nearest maximum measurement
  • Nearest maximum 24h average measurement
The nearest five reactors are retrieved once at startup of the QuickApp or at the next interval if you click on the button.
Radioactive@Home is a Polish science project using the distributed computing capabilities of the BOINC platform. The main goal of the project is to create a free and continuously updated map of radiation levels available for everyone, by gathering information about gamma radiation using sensors connected to the computers of volunteers willing to participate in the project. Project is completely non-commercial, participating will be free of charge (excluding cost of detector) and the software will be licensed under the GNU General Public License (GPL).
μSv/h: The sievert (symbol: Sv) is a unit in the International System of Units (SI) intended to represent the stochastic health risk of ionizing radiation.
In land navigation, a 'bearing' is ordinarily calculated in a clockwise direction starting from a reference direction of 0° and increasing to 359.9 degrees. Measured in this way, a bearing is referred to as an azimuth by the US Army but not by armies in other English speaking nations, which use the term bearing.
The human population is continuously exposed to ionizing radiation from several natural sources (cosmic and terrestrial contributions). For most individuals, exposure to natural sources exceeds that from all man-made (artificial) sources combined. The man-made sources arise from peaceful (e.g. medical use, energy generation, and associated fuel cycle facilities, radioisotope production, waste management) and military purposes (nuclear tests and their fallout or radioactive release, nuclear explosions).
Radiation levels:
Green: Radiation up to 0.3 μSv/h
Yellow: Radiation between 0.3 and 0.8 μSv/h
Red: Radiation above 0.8 μSv/h
1.14 µSv/h - Shelter population
5.7 µSv/h - Evacuation of population
11.4 µSv/h - Issue Iodine tablets
0.114 µSv/h - Max daily dose == 1 mSv/year
Reverse Geocoding by Nominatim
Reverse geocoding generates an address from a latitude and longitude. The reverse geocoding API does not exactly compute the address for the coordinate it receives. It works by finding the closest suitable OSM object and returning its address information. This may occasionally lead to unexpected results.
/monthly_2022_11/radiation-monitor-1c.png.762783dcc152d2602bb666ee45869ef9.png" />
QuickApp code logics:
  • onInit() Initialise the QuickApp
  • getQuickAppVariables() Get all Quickapp Variables or create them
  • createVariables() Setup the global variables
  • setupChildDevices() -- Setup all child devices
  • loadMap() Get the webpage from
    (This is the main loop of the QuickApp)
  • extractData() Extract the data from the webpage source-code
  • geoDistance() Calculate the distance from the HC3 (QuickApp variables) lat/lon to the sensors lat/lon
  • geoBearing() Calculate the bearing from the HC3 (QuickApp variables) lat/lon to the sensors lat/lon
  • Check for the values to give the right dot colours for the sample and average measurements
  • Store the values of all sensors in a table and sort the table on distance
  • Run through the table to get the maximum sample and maximum average measurements. If there are more than one, get the one that is the nearest-by
  • updateIcon() Set the icon (colour) based on the sensor measurement
  • getCity() Get the cities and countries for the seven selected sensors from
    and store them in a table
  • updateLabels() Update the labels
  • updateProperties() Update the properties
  • updateChildDevices() Update the Child Devices
  • Return to the main loop loadMap()
Links:
  • Radioactive@Home Map:
  • Status servers:
  • Reverse geocoding:
    licence:Data © OpenStreetMap contributors, ODbL 1.0.
  • Nominatim Usage Policy (aka Geocoding Policy):
Variables (mandatory and created automatically):
  • latitude = Latitude of your location (Default is the latitude of your HC3)
  • longitude = Longitude of your location (Default is the longitude of your HC3)
  • language = Preferred language (default = en) (supported languages are English (en), French (fr), Polish (pl), Croatian (hr) and Dutch (nl))
  • interval = Interval in seconds to get the data from the Radioactive@Home website
  • debugLevel = Number (1=some, 2=few, 3=most, 4=all) (default = 1, debugLevel 4 is only recommended for solving difficult issues)
  • icon_refresh = User defined icon number for refresh status
  • icon_green = User defined icon number for values less than 0.3 μSv/h
  • icon_yellow = User defined icon number for values between 0.3 and 0.8 μSv/h
  • icon_red = User defined icon number for values greater than 0.8 μSv/h
  • icon_error = User defined icon number in case of an error gettng the data
Version 1.4 (6th February 2024)
  • Added extra check for an empty response in the address from Geocity (thanks to @Sankotronic from the Fibaro forum)
Version 1.3 (17th July 2023)
  • Added extra check for the right response from Geocity (in case of response {"error":"Unable to geocode"})
Version 1.2 (11th January 2023)
  • Added support for Croatian language thanks to @Sankotronic
Version 1.1 (9th January 2023)
  • Changed handling of negative values for dots and icons: if tonumber(num) >= 0 and tonumber(num) <= 0.3 then
  • Added a better translation for French (thanks to @fredokl)
Version 1.0 (5th November 2022)
  • Added the nearest five reactors to the labels with distance and bearing
  • Added a button to refresh the list of (five nearest) reactors
  • Added a warning at startup if the latitude or longitude differs from the setup of your HC3
  • Replaced the creation of the dots 🟢🟡🔴 to the labels, so no longer for all sensors
  • Added some extra notifications to the labels in case the website is down
  • Extended the http timeout a bit, to give the reverse geocoding some more time to respond
  • Added translations for new functions
Version 0.5 (29th October 2022)
  • Added translation to the Reverse API geocoding response (city and country)
  • Changed calculation of the bearings only for the 7 selected sensors, not all sensors
  • Optimized the code and added more structure by using multi file code (main, childs and i18n)
Version 0.4 (22nd October 2022)
  • Added six Child devices for the nearest sensor 24h average, 2nd, 3rd, 4th, 5th nearest sensor sample, the nearest sensor maximum sample and the nearest sensor maximum 24h average
  • Added icons based on sensor measurements to all Child Devices
  • Added translations for the labels and properties from English to French, Polish and Dutch. (Thanks to @ppeterr and @fredokl for help with the translation)
  • Limited the details of the response of the Reverse Geocoding with zoom=10 (address detail = city)
Version 0.3 (16th October 2022)
  • Added the City and Country also for worst sample and worst average sensors
  • Added all debug information and set the debug levels
  • Optimised the code
Version 0.2 (15th October 2022)
  • Added the City and Country for all 5 sensors, not only the first one
Version 0.1 (15th October 2022)
  • Initial version
Download the QuickApp here (download the file and un-zip):
or from the Fibaro Marketplace:
How to install:
  1. Open the Configuration Interface
  2. Go to Settings > Devices
  3. Click  +
  4. Choose Other Device
  5. Choose Upload File
  6. Choose file from your computer with .fqa
Icons thanks to @Sankotronic
image.png.69f69625580adda6e16fa2a12cf0b851.pngimage.png.34c11c6855da86a0ab686982678aea0c.pngimage.png.6170fc1e918407462f60261d0ef3ebc9.pngimage.png.b02b02f067cca39ea6e1971795241863.pngimage.png.61ed78e363bbafd8d3447f5308223746.png
Edited by SmartHomeEddy
  • Like 5
Oepsie or what?
/monthly_2023_06/image.png.86f0451643ff391bdf3f845b7686aedd.png" />
    Strange graph
    faulty sensor i think. 9033 4033 9033
    Ok, I will turn the windows open and remove the ducktape on the door and window frames
    what what...bbbb aaaa bad reception ffff rrrrr om the nuclear atomic basement....
    Edited by ppeterr
    Uploaded a new version.
    Added an extra check for the right response from Geocity (in case of response {"error":"Unable to geocode"}) to prevent a crash 🥶
    You can install the new QuickApp (Radiation_Monitor_main.fqa) or update the main file (Radiation_Monitor_main-13.lua).
    The site from radioactiveathome.org has been down for a few days, so you don't get actual readings in your Quickapp.
    BOINC@Poland posted:
    Quote
    Radioactive - unplanned technical break.
    Due to problems with the hardware, the server designed for Radioactive@home has been turned off.
    Details and possible news from the front line of fighting with the hardware on our
    I hope they can get it working soon.
    And its working again. The radioactiveathome.org site is running again.
    Hello @SmartHomeEddy ,
    I noticed that my copy of Radiation Monitor QA is not working. I checked and found following debug:
    It seems that sometimes successful call to openstreetmap does not give address part. I have added check if there is address part and if not found then empty data is stored to table. Now it is working without problem and I still have all stations city name shown on children.
    Sorry, I think I have version 1.1, so you probably already solved this problem. :-)
    Edited by Sankotronic
    added version
    Thanks @Sankotronic
    it does sound a bit familiar, but my brains have a bit if a memory leak 😉
    In version 1.3 I did solve something with Geocity response in case response status (200-300) and response data (an error message from Geocity).
    (In version 1.2 I added Croatian language 😃
    Hi @SmartHomeEddy ,
    My copy has Croatian translation and Geocity response status check, but last mentioned version in main.lua part is 1.1. Since my brains have a bit memory leak too, I don't remember if I just changed some code myself or I copied it from you.
    Anyway I just change code line 286 to this:
    Code was sometimes failing on missing jsonTable.address part.
    I haven't got an empty address error up till now, but that apparently depends on the location you are at. Or the status check in version 1.3 helps.
    Could you run version 1.3 to check if you get the same error?
    GeoCity can also give a response "Unable to geocode", next to status <200 and >=300.
    In that part of the code I have in version 1.3 this code:
    So I understand there also can be a situation with an address == nil
    Maybe we could combine this to:
    Hi @SmartHomeEddy ,
    This code:
    is working properly. I did get one warning, but QA didn't crash, so additional check is OK! Thanks!
    Thanks !
    I will add it to the code for version 1.4 and publish the new version.
    Added extra check for an empty response in the address from Geocity (thanks @Sankotronic)
    You can replace the code from the main file to get the latest version working.
    Hello! The QA hasn't been working for a while. The website
    seems to be down. Can you confirm this?
    The website is going through some tough times. It is based upon volunteers and donations. Indeed the website is up and down, down at this moment, sometimes up again.
    Ah, okay.
