Szakos 0
I have an issue with RGBW2 ( 442 ) and Toggle switch installation with HC3 Home Center.
I use just White LED strip this case I adjusted the parameter Nr. 150 from 0 to 1 ( HSB and White mode ).
Also I modified the parameter Nr.23 from 2 to 4 ( Toggle switch just ON/OFF ).
I use Input4 for the Toggle switch and OUT4 for the LED strip.
The problem is when I switch with the Toggle switch the in the application the "Power Switch" ( icon ) dosn't change.
1, If in the application the "Power Switch" is on than the LED lighting. I can switch OFF with the Toggleswitch but in the application the "Power Switch" still reemain in the ON position. In this variant I can ON/OFF with the togglr switch without any problem.
2, If I switched off the LED strip in the application with the "Power Switch" ( push the icom ) and afte I want to switch ON by Toggle switch it is impossible. The LED strip and the application icon ( Power Switch ) dosn't react of any position for the toogle switch.
If anybody use HC3/HC3 Lite with RGBW2 and Toggle switch can share to me what is the correct parameter adjustment ?
I want to use Toggle switch just for ON/OFF the LED strip without adjust the Brightness. Brightness will be adjust just in the application.
Thank you.
