Another lights of after timer/motion
I have been looking around to find the simplest? solution to turn on a light triggered by a motion sensor but restarting the timer and I think my code is short enough but as I am no coder syntax is wrong. At least that's what I think. Code stolen and adapted from various places... (sorry if not allowed but where do a beginner start)
First my conditions
Quote
then my actions
5 answers to this question
Strange that it is possible to save the scene with a double operator in the last condition.
Change the last part to
and check your scene setting about allowing the restart of a running scene, yes (default) or no
9 minutes ago, Whswede said:
What is switch? I do not see it in your code.
11 minutes ago, Whswede said:
Same question about timer
You mean this?
I am not saying it is going to work, it might, but you say you are a beginner so let us get past the basic errors first.
Change your line:
to: local movement, modifytime = fibaro.get(motion1, "value")
or: local movement = fibaro.getValue(motion1, "value")
or without the local variable movement just say:  if  fibaro.getValue(motion1, "value") then horntimer = ..... etc.
    You mean this?
    Great! It kinda works now :)
    Code looks like this now. (removed condition on id 90 temporary)
    Adjusted the actions. Switch is replaced by light1.
    I also adjusted the local value movement
    BUT the code does not seem to be triggered by the motion sensor. I can run the code manually and it loops fine and turns the light off if no movement but i never lights up again. I solved it temporarily by adding a simple block scene that runs this LUA-scene whenever motion is detected. Scene is set to run auto and not disabled. What is missing for it run triggered by sensor ID193 ?
    Yeah, that was the issue. Code works fine now. Thank's alot!
