Jonasz 0
Hi Everyone,
Newbie here. I have successfully installed a smart implant to control by garage door. It acts as a push button.
My problems:
1 - I would like to have the HC3 web interface (or yubi) to display a push (momentary) switch icon instead of a on/off switch icon, is it possible?
2 - I only have a small number of available icons in HC3, for exemple I can select for my smart implant a bulb icon or a siren icon, but not a garage door icon. Is there a way to solve this?
3 - Last but not least, I would like to get information about when the garage door is open and when it is closed, without using any existing hardware. I imagine that it could be possible to have some kind of seen or quick app that would do the following:
- set up a variable somewhere called "status"
- when switch is activated the first time set status to 1, when it is activated the second time it sets the status to 0, and so on...
is there an easy way to do this and get some kind of icon displaying the status of the garage door?
Thank you in advance
