I have a scene for controling my sprinklers. The sprinkles are controled with an RGBW module and this can not be added in Irrigation Panel .so i created a scene and a variable in Variables Panel with options "Yes" and "No" This scene has to start irrigations on scheluled time and if a variable (NecesitaIrigare) has value "Yes". The scene start irrigations  even if the variable has another value.
I suppose I can't help, but you can help others to understand your scene:
change the system to 'English' and take a new screenshot.
That's interesting... how and when do you set the global variable (post your exact command) ? Since I believe it's Romanian language, do you need to set the variable to "Yes" or to "Da"?
