kalypso44 0
Good morning,
I want to automate the light in my garage which today works with 2 neon lights and 3 push buttons on a remote control switch.
The idea:
Remove the remote switch, and installation of EUTONOMY D212NP in din format directly on the electrical panel.
Modification of the neon strip (remove ballast and starter), and put dimmable led tubes instead.
They will be dimmable, although I may not use them! I will test...
I'm not an electrician, I have some basics, and have a multimeter and a phase (voltage) tester, and wago
Before any modification, I seek the opinion of those who control to avoid problems, or error, confusion.
The circuit breaker:
Powers the remote switch (phase and neutral), and a neutral that goes to the bulb
The switch:
I have a phase (1) and a neutral (A1) which from the circuit breaker feeds the remote switch.
Then I have a wire (2) to go to the bulb ~ and the other (A2) for the buttons (B)
But I dry up miserably on the wire of the buttons (A2) which I have left on the remote control.
I'm not sure of myself!
How would you plug it into the euFIX D212?
On the image of the electrical diagram, the button seems to me to be toggled with one or the other, that's where it bothers me...
I have 3 push buttons, so I don't know how to connect my button wire (A2) to the euFIX D212
4 answers to this question
