knuth 29
I would like one of my KeyFob actions to set the level of a RGBW controller 2 to 90 %. I use the "set level" option in the KeyFob menu, set the level at 90 % and store the result. When I reopen this menu, it looks like this:
/monthly_2023_08/image.png.88824be3a09640ce58c01c299f4a970c.png" />The level is set back to 49%, not 90 % as entered before I hit "Next". What is going on? Is the KeyFob "Set level" command not compatible with the RGBW controller?
Furthermore, even the "set level at 49%" does not seem to work. There is no response from the LED light to this command. "Turn on" and "turn off" work as expected on the same RGBW controlled LED lights.
