Help Needed : How to override scene if light is turned on manually
Hi everyone,
I have a lua scene that turns a light on when motion is detected and turns it off after 1 minute.
How can I make it not turn the light off if it has been previously turned on manually using the switch?
Here is the code for the scene
  conditions = { {
      id = 220,
      isTrigger = true,
      operator = "==",
      property = "value",
      type = "device",
      value = true
  operator = "all"
fibaro.call(185'turnOn')
fibaro.setTimeout(60000function()
fibaro.call(185'turnOff')
end)
Thanks a lot
(This lookes like a HC3 scene, but your setting say you have a HC2)
You could use a simple HC3 blockscene, that next to the check on motion also checks if the light isn’t already on. That only works if you can turn on the light before motion is detected. So if you turn on the light, if after that motion is detected, the scene doesn’t activate.
