Export temperature chart data
Guys, anyone know how can i export temperature sensor's data from chart?
I need to get a longer period (a month maybe) with all values and times measured by the sensor.
Thanks in advance
Yes, maybe there is something wrong with how I specify the api query to /events/history ?
    well in this case none of similar devices would be seen, but i tried it with other swithches, and i could see the events.
    Try this version
    and call it as
    16 minutes ago, jgab said:
    Try this version
    and call it as
    this works
    I don't now why there are double events
    I see them in my history too.
    I would expect every other turnOn and turnOff
    @jgab, getting error
    Don’t declare exportTemps as local
    @jgab sorry to paste incomplete rules
    You gave me
    if I blanc out local data = exportTemps
    it generate next error
    So I am a tad lost
    Your exportTemps return nil.
    Can you show the whole code section including the declarations of exportTemps + helper functions and the rules?
    @jgab I have no clue what I did wrong.
    I redid the whole QA and I don't have any error so I made a typo somewhere, sorry.
    This I like it show after restart QA the data of those temperature devices.
    The email does't arrive??
    You need to set 'user' in user:email =
    to something valid. Try 2 as it is usually the admin...
    @jgab at the beginning of the QA  is mentioned other  rules with email  are okay
    Ok, so ER5 has "old" code that only allows 1 id for the email. Try to only use 2 for the rule, like 2:email = ...
    I will fix it in the next release
    Result>>is sending two emails, email addresses are different.
    Any other idea????
    Edited by Sjakie
    add question
    Any other idea????
    Use only one?
    @jgab If I use {2,20} or {2} or 2 it does't make any difference error stays
    but this error has nothing to do with the users. This is exportTemps(...) returning nil. Have you declared it global?
    @jgab, sorry lets start again to avoid confusion.
    This is giving me the problem
    Ok, so how and where did you define exportTemps? remember it can't be local.
    ok if it can't be local I create GV also wrong!
    I also have this
