SmartHomeEddy 828
This QuickApp calculates the cheapest prices for using appliances based on the hourly Tibber energy prices.
This QuickApp is especially useful for appliances (like charging your car and washing the dishes) that need to run once a day, within a timeframe and during some hours.
You can use more than one instance of this QuickApp if you need more than one appliance to start in the cheapest hour but not within the same timeslot.
Tibber today and tomorrow prices
The tomorrow prices are available from 13:00 hour.
If the tomorrow prices aren't available yet and the timeslot is (partially) tomorrow, a temporary calculation and start-stop plan is made with the today prices, until the tomorrow prices are available.
If the start time plus duration is (partially) tomorrow, for example start time 18:00 and duration 7 hours, the calculation can be made from 13:00 hour when the tomorrow prices are available.
/monthly_2024_06/image.png.8cca725a501aef5f243d1b478fc25b81.png" />At 04:00 the binary switch will turn ON and at 07:00 the binary switch will turn OFF.
You would still have to create a script, triggers by this binary switch, to actually turn on the charging of your car, or turn on the dishwasher.
IMPORTANT
This QuickApp needs the Tibber Monitor QuickApp to run on your HC3.
It is important to synchonise this QuickApp with the timing of your Tibber Monitor QuickApp.
This QuickApp works at its best, if you setup the interval with the intervalOffset just after the Tibber Monitor runs.
If you Tibber Monitor runs at 5 minutes (300 seconds) after the whole hour, run this QuickApp 5 minutes and 10 seconds (310 seconds) after the whole hour to be sure to get the prices from Tibber Monitor.
This QuickApp runs every whole hour to turn the switch on and off. If it is time to get the prices from the Tibber Monitor QuickApp, this QuickApp runs every whole hour plus the seconds set in the intervalOffset.
QuickApp logics
DISCLAIMERS
Use this QuickApp at your own risk. You are responsible for ensuring that the information provided via this QuickApp do not contain errors.
Tibber is a registered trademark being the property of TIBBER. TIBBER reserves all rights to the registered trademarks.
Information which is published on TIBBER’s websites belongs to TIBBER or is used with the permission of the rights holder.
Making of copies, presentations, distribution, display or any other transfer of the information on the website to the public is, except for strictly private use, prohibited unless done with the consent of TIBBER.
Published material on dedicated TIBBER press websites, intended for public use, is exempt from the consent requirement.
Also see:
Tibber API documentation:
Tibber API explorer:
Tibber status:
Variables (mandatory and created automatically)
Changes version 1.0 (20th June 2024)
Changes version 0.3 (19th March 2024)
Changes version 0.2 (15th February 2024)
Initial (beta) version 0.1 (11th February 2024)
How to install
26 answers to this question
