Stony 1
Hi, I have a number of Fibaro Z-WAVE devices integrated with HC3. As the RoutingInfo script shows, all devices are directly connected to the Main Center, despite there are 3 Fibaro Wall plugs in the system but it seems, none of these is used as Repeater. One of those is located physically between the Center and some smoke sensors, but again, the WP repeater is not used. The smoke sensor furthest away from the Center is not connecting to the Center, but that wall plug would be actually very close (but is not used as repeater by the sensor). Is there a way to get the distant sensors to use the wall plug repeater or to force it somehow? May also be that there is a parameter, which I need to set - but I have not found one yet.
Thank you for your help.
14 answers to this question
