tips for self:updateProperty("log",
Hi all.
I am currently creating a QA for my iZone AC system and came across the "log" property.
I currently have a temperature and vent mode displayed along with an icon of the temperature sensor:
/monthly_2025_01/image.png.7ca7750eebb0fb97afae65909ecd2983.png" />
I was wondering three things:
1. is it possible to put superscript in somehow so I can display oC for the units?
2. is it possible to change the color etc of the log text? I tried with HTML tags but didn't seem to work
3. Finally - is there a way that I can send the temperature to be logged so it appears on the temperature chart under the General tab?
Thanks in advance,
Anthony
6 answers to this question
You don't have to use superscript, just use these characters to show in the unit: °C
"Old fashion" HTML will work, bot not at all. It's a way of experiments, what works, what not, on example: table, align, FGcolor, BGcolor, font, face, size, width - all works. CSS doesn't work.
However, there's much you can do using HTML. Below is the example, using QA interface's label field, all done with above few tags. Behaviour on console is not the same, but very similar.
    Thanks Lukas. I have that worked out for the QA itself - it's just the "log" that I can't seem to get working.
     Thanks Lukas - I have this working in the QA labels etc. I just can't get it to work in the "Log" property.
    Do you ever find sometimes you make things so complex that the obvious easy method never enters your mind!?!
    Thanks!
    I'm wondering, what's the problem with "log"? Saying "log" do you mean the console where all the messages are displayed in the HC3?
    There's a way to alter the system color of font in console: by using HTML tag. When I take the HTML code to produce above table in QA and do
    print(html_code)
    the result will be the same (or very similar) on the console. So, you should not expect heavy troubles with coloring text on the console ("log") - maybe the HTML is improper or you use a style (CSS) or a tag which is not supported?
    print(html_code)
    No - so the log is the line of text that appears under the icon in the Whole House dashboard. I have a picture of it in my original message above. I have the HTML working well for the QA labels and the console - just not this!
    Aha. I such case - I can't help.
